Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  8
Thanks Thanks:  1
Results 1 to 10 of 10
Thread: Tire pressure drop
    150+ Posts geraldlanc's Avatar
    austin tx usa
    Default Tire pressure drop
    My 08 CSC front tire was leaking air, almost flat in 5 days. I had a new tire installed, and overnight, it dropped about a pound of air. Is that normal? It went from 40 psi to 39.
    Gerald
    When temperatures drop over night you could see a pressure drop. Keep and eye on it. If it comes back up after riding on it, then it's temperature related.
    Other things would be did they replace the valve stem? Maybe check the valve is snug in the stem? It's kind of rare, but, aluminum wheels can get pinholes or porosity depending on their environment.
    Quote Originally Posted by geraldlanc View Post
    Gerald
    It is possible with a new tire.....Check it again in a day and see if it still loses some air...
    Also one pound is not so serious...You could lose a pound just by checking it a few times most gages are not that accurate to the pound...
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    If it keeps dropping go out and ride it and get it good and warm.
    This helps seat them sometimes if you have a slow leak especially when new.
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
    Not uncommon to lose 1lbs of pressure keeping in mind most air gauges will lose PSI when checking pressures. Mix up some dish soap and spray the tire and wheel and check for leaks. Check it again in a day or 2. Good Luck
    Apr 2010
    Shenandoah Valley of Virginia
    Gerald
    I've seen tire gauges vary a pound from check to check, both ways, back to back, especially if it drops the pound as you just let some air molecules out of the tire and into the gauge to be checked for squeeze. That give them other molecules more room inside the tire, like more elbow room. Those that came out to be checked are then set free to join the others that we breathe.
    There are other factors, like the temperature of the air used at inflation vs temp of the same air when checked. If pumped in while in a warm tire shop from a running compressor vs checking it after it's parked and rested at home 6 hours later at 7:00pm on a cool evening.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Gerald
    It sure sounds like the valve stem to me unless you have corrosion around the wheel bead.
    Jim Murphy
    Iron Butt Rider 2001
    Some soapy water on and around the stem and bead will help to identify a leak, take the valve cap off the stem and soak the core you may find some bubbles, I like to push on the valve stem ( side to side ) when checking for leaks also
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    I would replace the Rubber Valve Stem. See attached photo.
    Name:  90 Deg. Valve Stem.jpg
    I only use the ones with the nut on the top of the rim as in the above photo.
    Dec 2012
    Quote Originally Posted by Gideon View Post
    I am sorry, I should have added a link that I have used.
    https://www.rockymountainatvmc.com/t...e-valve-stem-p
    Ride safe,
    Bob aka Gideon
  1. Tire Pressure for MPA Front Tire
    By cScjhb in forum Honda Trikes
    Last Post: 09-13-2020, 12:11 PM
  2. Replies: 17
    Last Post: 01-22-2019, 02:57 PM
  3. tire pressure???? suspension pressure???
    By flangar in forum Stallion Trikes
    Last Post: 05-10-2014, 09:53 PM
  4. Gas Mileage Drop After Stage One Upgrade:
    By dfpk in forum Harley Trike Conversions
    Last Post: 03-30-2014, 05:29 PM
