ADSavarese11Jack KlarichNew Member Introduct...New member from FL
ADSavarese11woodyNew Member Introduct...New member from FL
LD-Ordie1LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11hardwickbvNew Member Introduct...New member from FL
ADSavarese11ol' schoolNew Member Introduct...New member from FL
ADSavarese11GorillaNew Member Introduct...New member from FL
ADSavarese11Marc HNew Member Introduct...New member from FL
ADSavarese11ADSavareseNew Member Introduct...New member from FL
ADSavarese11Phu CatNew Member Introduct...New member from FL
ADSavarese11trike ladyNew Member Introduct...New member from FL
ADSavarese11Uncle FesterNew Member Introduct...New member from FL
ADSavarese11rhino 2New Member Introduct...New member from FL
Likes Likes:  8
Results 1 to 20 of 32
Thread: Looking to make my trike sound loud with minimal dollars
    Oct 2020
    Fairfield, PA USA
    Default Looking to make my trike sound loud with minimal dollars
    I am looking to make my trike louder with out needing a tuner. Dealer told me to update my air cleaner to a stage 1 and that would improve it and than I could also add some slip on exhaust pipes. Any suggestions out there?
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by 4Wheelrocker View Post
    I would contact 1 of our sponsors, DK Custom Products. Good people all and Kevin has done more TriGlide testing on air cleaners, exhaust and suspension, as well as heat reduction.
    Oct 2020
    Fairfield, PA USA
    Thank You
    100+ Posts Longbeard71's Avatar
    Nov 2018
    Talbott tn usa
    Cut the baffles out of the stock slip ons. Install Torque Thrust Inserts from DKcustoms. That is the set up i have and sounds very good. I also removed the cat out of the head pipe.
    Jan 2009
    MA,
    Take a 1 inch hole saw and drill the center of the baffle out in the end of the muffler's easy to do sounds great , you can do it with the mufflers on the bike.
    Have a look here for air cleaners from our sponsor D K Customs. http://www.dkcustomproducts.com/acl/...er-systems.htm
    They have done extensive testing on all their products
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    Why do you want your trike to sound louder???
    1. Make it go faster
    2. Make people pay attention to you
    3. Just to piss people off
    4. Make little boys and girls cover their ears and cry
    TAYQ: Cheapest way = knock out stock baffles
    IBA#61162
    PATRIOT GUARD
    USMC
    1000+ Posts
    Aug 2016
    Des Moines IA US
    If putting a stage one air cleaner on and then slip on's, you will need a tuner, not a mechanic but have heard this many times, to much air flow and a tuner helps this out.
    As many has said knock out the baffles and put in the torque inserts from DK Customs, myself I have had loud on many bikes and now I'm happy with the sound of stock pipes on my 2018 triglide.
    Look at the video on youtube with the cobra 909's on a triglide, good sound IMHO.
    All for now Trampas
    Oct 2020
    Fairfield, PA USA
    Default Brilliant minds think alike
    That is what I was thinking but than it would fail my yearly inspection.
  11. #10
    150+ Posts David792's Avatar
    Mar 2019
    Idaho Falls, Idaho, United States
    Default Hate me if you must
    Well, I'm gonna piss a lot of people off, but here goes...
    Like you, I paid a good deal of cash for the best three wheeled motorcycle available. Please don't start drilling holes in things and chipping out cats with hammers. (there's even an online business that will do it for you). Spend your Christmas cash and DIY it or have it professionally done. https://www.opusharley-davidson.com/customs/stage-1-2-upgrade
    A dealer will charge $2,000... maybe less. For half the cost you can EASILY do the job yourself.
    2018 Tri Glide Ultra Classic. Vivid Black.
  12. #11
    150+ Posts KJB's Avatar
    Oct 2014
    NE WI & SW FL
    I just had the dealer install Street Canons after they did a demonstration of a showroom Trike with and a showroom Trike without. Louder than stock but a comfortable loud for me.
  13. #12
    HD has a stage one air cleaner and "Download" for the ecm that would be cheaper than a tuner. For example, a Power Vision is gonna run you between $400 and $600, the download is gonna run about $199. Both are after the cost of the air cleaner.
    You can do slip ons without doing the air cleaner and download or tuner. Pretty much all your gonna get is sound. Maybe a slight increase in power.
    By doing slip ons, air cleaner and tuner you'll get both. Just depends on what you're looking for.
    Please don't drill out your mufflers, you probably will fail inspections and void the warrantee if you still have one. HD makes a tuner that does not void the warrantee, IMHO, not as good as a power vision, but, you still have the warrantee.
  14. #13
    Jul 2020
    Willits
    Default Stage1 kit and Rinehart 4in slip on did it for me
    I took my 2020 Tri Glide into the dealership had a stage 1 upgrade done ($$$) with Rinehart slip on and a lift kit ( so I would not scrape the exhaust when going over a dip, speed bump)in my humble opinion I think it was well worth the money, the looks and sound of the exhaust pipes are much improved. You decide, your Trike your money your decision.
  15. #14
    GLEN ELLYN, IL. USA
    Quote Originally Posted by Phil1839 View Post
    JMHO and I'll get a lot of hate mail on this, but I think Rinehart's should be illegal. 2 members of my chapter have them and I can't ride anywhere near them without earplugs.
    Obnoxious!! But that's what some riders want.
    IBA#61162
    PATRIOT GUARD
    USMC
  16. #15
    450+ Posts arnie's Avatar
    Dec 2011
    camp grove,il.usa
    Gary I know exactly what you are saying. Some Rineharts are good some are not, i'm not sure what model is good & what one isn't, but some have the raspy sound that just annoys the heck out me. A friend of mine has some cobra's that sound great at idle, & good down the road when behind him. I rode his trike & it was so loud I swapped back to mine real fast. It's getting more difficult for me to find what I like with the M8 motor.
  17. DKCustoms postbit
  18. #16
    Dec 2011
    camp grove,il.usa
    Alan, around here you have to purchase the tuner, they offer no downloads.
  19. #17
    Quote Originally Posted by arnie View Post
    In that case ... I would definitely go with the power vision ... I absolutely love mine ... Had it on 2 or 3 rides ... getting old and memory is not what it used to be.
  20. #18
    GLEN ELLYN, IL. USA
    Arnie. I do have the Cobra Race Pro slip ons - not the Neighbor Haters. The black tips really add a nice touch. They are a deep mellow sound not loud and obnoxious. I don't see them on the Cobra website anymore so I don't know if they are still available for the trike
    IBA#61162
    PATRIOT GUARD
    USMC
  21. #19
    Dec 2011
    camp grove,il.usa
    I have cvo mufflers with fulsac baffle kit. They were great on my 103's, but not on my M8. I pulled the baffles out & the packing is all gone! I ordered some ceramic baffle wrap hopefully that will get the sound back that I like.
  22. #20
    Feb 2017
    Dismond Oh USA
    Default mufflers
    check these guys out https://americancustom.com/collectio...uring-mufflers Good sound for low bucks
  1. Loud pipes are TOO loud!
    By zoood in forum Harley Trike Conversions
    Last Post: 06-25-2014, 08:15 AM
  2. Bad LOUD Thumping Sound
    By Blueribbon in forum Honda Trikes
    Last Post: 04-26-2014, 10:07 AM
