Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  1
Results 1 to 6 of 6
Thread: frontend lift
    Apr 2019
    bullhead city az moh
    Default frontend lift
    hello
    i have vw trike with a 1984 goldwind front end it runs great only when i startup from a stop slow the front end will rise up abut 1 1/2 the movement is in the forks the wheel stays on the ground fells like there is to much movement inside the forks ???
    Welcome to the Gang from Western Colorado.
    Since it's a VW trike, I'm assuming it's rear engine (I've only seen a few mid engine VW Trikes). I suspect there is a disproportionate amount of weight in the rear. I also suspect on a jack rabbit start, the wheel might come off the ground.
    I think one of the VW tech's will chime in soon, pretty save group of guys.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    It sounds like you are talking about the normal amount of pre-load and droop that is standard for a soft riding telescoping fork.
    You don't want to be banging into the upwards limits of the fork all the time. Not only would that be annoying....it would be dangerous also.
    The age of your fork may make parts hard to get. But there is/was some very nice progressive rate aftermarket springs available.
    But....are you talking about for/aft slack?
    I know I beat the bushings up real bad in my wing forks on my trike, wheelies and slam downs were rough on it ...... Vw engine in the front.
    Apr 2019
    Default lift
    it would be the for, just as i take off
    Apr 2019
    Default bike lift
    well in checking the forks out in found on progressive spring on the right and the stock two part spring on the left could be a problem ?
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Any stock spring from a goldwing is gonna be too stiff. Cutting a spring in half or shortening it will make it stiffer. My fork springs are from an xr80 or 85 can't remember it's so long ago. Unless you have a hundred pound headlight. That would change things.
  1. Frontend
    By Exnavyabfc in forum Harley Freewheeler / Road Glide 3
    Last Post: 02-28-2018, 10:44 AM
  2. Eurowing frontend, anyone have one
    By triwinggirl in forum Honda Trikes
    Last Post: 01-21-2018, 08:43 AM
  3. Frontend
    Last Post: 07-25-2017, 06:34 AM
  4. GoldWing / Eurowing Frontend
    By triwinggirl in forum Other Brands Trikes
    Last Post: 07-11-2016, 11:24 PM
  5. leaf spring frontend ???
    By bj tribble in forum VW Powered Trikes
    Last Post: 01-20-2012, 08:22 PM
