BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  4
Thanks Thanks:  6
Results 1 to 7 of 7
Thread: cSc Air Suspension Photos Needed
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    Default cSc Air Suspension Photos Needed
    The Valkyrie suspension setup on my trike has two coil spring shocks and one air shock. The air shock is a Honda 1500 Goldwing shock.
    Can anyone supply me a photo without the body?
    Ride safe
    God bless,
    Bob...aka...Gideon
    Name:  LINEX Gideon 2.jpg
    Dec 2012
    Can anyone from cSc provide installation photos?
    Sponsor
    TrikeTalk Sponsor
    Trikemaker's Avatar
    Aug 2017
    Arrington, VA, USA
    Hi Gideon,
    We have looked and can't find any good pictures of a Sport trike without the body. Is there a specific question that you need answered that we can help with?
    Dec 2012
    Quote Originally Posted by Trikemaker View Post
    Hi Gideon,
    We have look and can't find any good pictures of a Sport trike without the body. Is there a specific question that you need answered that we can help with?
    The Air Shock will not hold air.
    The air valve is on the left side below the seat when siting on the Trike.
    Can the airline be repaired/replaced without removing the body?
    Will I damage the “Air Shock” if I continue to ride the Trike?
    If the body needs to come off, would you suggest changing to different suspension system?
    How is cSc converting older Valkyries now?
    Do you still use a Honda Air Shock?
    Thank you for your reply.
    Sponsor
    TrikeTalk Sponsor
    Trikemaker's Avatar
    Aug 2017
    Arrington, VA, USA
    Hi Gideon,
    I will attempt to answer your questions in order, but first an FYI. What you are calling the air shock is not actually a shock at all. It is simply a helper air spring. It does not do any actual damping. It is in fact the original Honda air spring from a 1500 Goldwing that we used to purchase new from Honda to supply with the Valkyrie kits.
    1. Yes you can repair the air line while the body is still on the trike.
    2. No you will not damage the air spring if you continue to ride the trike.
    3. I would definitely not suggest changing to a different suspension system. We do not offer any other suspension for a Valkyrie, and I don't think there is any need to do that if the rest of the components are still in good shape.
    4. Unfortunately we don't convert Valkyries any more. We have not offered a Valkyrie kit for at least 10 years as there just isn't any more demand.
    5. All of the Valkyrie kits that we manufactured over the years used the air spring.
    You can repair your air line simply by removing the fittings from the shrader valve and the spring and cutting about a half an inch from each end of the air line. This will remove the old crimped part of the line. Then just reassemble. That should fix your leak for another 20 years. If by chance it doesn't fix it we have replacement air line and fittings in house.
    I hope this helps.
    Dec 2012
    Todd,
    Thank you for the information. I appreciate your taking time to reply.
    God bless,
    Bob...aka...Gideon
    Dec 2012
    Good News, nothing wrong with the suspension !
    My local dealer picked up my trike this past Tuesday. They checked the air pressure and found it to be 42lb.
    They also did the soapy water test and did not find any leaks. Checked it again this morning, still 42lb.
    The cost for pickup and delivery plus service charge will be more than what I will spend for a new Precision Air Fork/ShockGage. But now I have peace of mind.
  1. Motor Trike Air Suspension Air Bag Replacement
    By bassfisher in forum Honda Trikes
    Last Post: 04-23-2023, 11:23 AM
  2. cSc Air Suspension Problem
    By Gideon in forum California Sidecar Trikes
    Owners Forum
    Last Post: 09-29-2020, 12:18 PM
  3. Rear suspension info needed
    By hawkeyefxr in forum VW Powered Trikes
    Last Post: 06-28-2015, 06:09 AM
  4. Which is best the Champion Independent Suspension or Solid Suspension.
    By glawrence7 in forum New Member Introductions
    Last Post: 11-24-2010, 12:00 AM
