14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  2
Results 1 to 4 of 4
Thread: Checking Oil on HD Trike
    5+ Posts Biker_ded's Avatar
    Jul 2020
    Hickory
    Default Checking Oil on HD Trike
    I have a 2014 HD Ultra with a recent Motor Trike conversion. I added a digital oil dipstick a couple years before I had the conversion done. The instructions say to check the oil level with the bike on side stand, which obviously can't be done with a trike.
    How have any of you overcome the "side stand" position when checking the oil, even with the standard oil dipstick?
    Any advice would be greatly appreciated!
    Quote Originally Posted by Biker_ded View Post
    The stock dip-stick on the Tri-Glide has two readings...1] Hot on Jiffy stand ; 2] Hot on level surface ....Don't know about the digital....
    If you want to be totally accurate ... you need to purchase the digital for the trike.
    I was in the same boat. I put the oem dip stick in using the "on level surface" reading and compared it to the digital. I forget weather it was a bar low or actually full ... that was on my 15 ... on my 14 I used the trike one.
    The reason I can't remember, I just put the right amount of fluid in and got a reading, then, used it to see if it changed. If it don't change, you're good. I mainly use the digital for temp.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    $150 dipstick !!!! WOW. Just put correct amount in ( or,some say 1/2 quart less) & check the stick ,Then you will know where it should be when checked later. not that hard. You can also buy a thermal gun to check temps a whole cheaper than 150 .
  1. Trike and checking your oil
    By Mcgee10 in forum Harley Trike Conversions
    Last Post: 05-15-2017, 06:50 PM
  2. Checking Oil Levels
    By Darby-Dawg in forum Harley Tri Glide
    Last Post: 11-23-2014, 04:09 PM
  3. Checking oil
    By roscoe 07 in forum Honda Trikes
    Last Post: 11-30-2012, 01:02 AM
  4. Checking the oil
    By 2blackbelts in forum VW Powered Trikes
    Last Post: 05-20-2012, 01:05 AM
  5. Checking the OIL after TRIKE Conversion
    By KRUZR in forum Harley Trike Conversions
    Last Post: 05-11-2011, 01:20 PM
