Have a 2008 Goldwing Champion trike. My heated grips and seats are not working, husband checked fuses and they are fine. Any suggestions?
I think if there is a problem with the grips the seat doesn't work either.Seems like its usually 1 grip but I can't remember which it is most often.
1989 GL1500 Goldwing (SOLD)
2006 GL1800 CSC
I replaced my heated seat with a custom seat w/o heat. I found that unplugging the seat resulted in loosing the grip heat. There was a dummy load that I had to install in the seat plug in order to get the grip heaters working again. Point is, it looks like the grip and seat heaters are ALL tied together and if one part goes bad, none of them work. This makes it hard to troubleshoot. But as suggested, start with the relay and go from there. Good luck..... Jim
2014 CanAm Spyder RTL SOLD
Semper Fi
Good info too know here: Just in case it does happen to any one of us............
I just put my Goldwing into it's hibernation mode yesterday 10/27/20 (so no heated seat or grips will be needed this season)
How did you install a dummy load to the seat heater?
Semper Fi
