Results 1 to 7 of 7
Thread: Heated grips and seats gold wing 2008
    Jul 2019
    Joaquin, TX. USA
    Default Heated grips and seats gold wing 2008
    Have a 2008 Goldwing Champion trike. My heated grips and seats are not working, husband checked fuses and they are fine. Any suggestions?
    Quote Originally Posted by Glenda McGinty View Post
    Have him check for relays ... if I remember there is a relay for those. Also, maybe clean the switches with contact cleaner ... Gold Wings are known for those getting dirty or corroded.
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    I think if there is a problem with the grips the seat doesn't work either.Seems like its usually 1 grip but I can't remember which it is most often.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Quote Originally Posted by Marc H View Post
    I replaced my heated seat with a custom seat w/o heat. I found that unplugging the seat resulted in loosing the grip heat. There was a dummy load that I had to install in the seat plug in order to get the grip heaters working again. Point is, it looks like the grip and seat heaters are ALL tied together and if one part goes bad, none of them work. This makes it hard to troubleshoot. But as suggested, start with the relay and go from there. Good luck..... Jim
    2014 CanAm Spyder RTL SOLD
    Semper Fi
    Sep 2016
    Springfield, Mass. USA
    Good info too know here: Just in case it does happen to any one of us............
    I just put my Goldwing into it's hibernation mode yesterday 10/27/20 (so no heated seat or grips will be needed this season)
    150+ Posts Backdraft's Avatar
    Sep 2013
    Pensacola FL,USA
    How did you install a dummy load to the seat heater?
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Quote Originally Posted by Backdraft View Post
    The dummy load was readily available from my dealer. Take a look on line. I believe it is made by Electrical Connection. It just plugs into the place where the heated seat plug was removed..... Jim
    Semper Fi
  1. Kuryakyn Grips Over Heated Grips
    By Danaman in forum Honda Trikes
    Last Post: 03-06-2019, 07:14 PM
  2. Kuryakyn ISO Grips over Heated Grips. (review/tip)
    By FuzzyWuzHe in forum Honda Trikes
    Last Post: 08-16-2017, 03:32 PM
