LD-Ordie2Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11Jack KlarichNew Member Introduct...New member from FL
ADSavarese11woodyNew Member Introduct...New member from FL
LD-Ordie2LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11hardwickbvNew Member Introduct...New member from FL
ADSavarese11ol' schoolNew Member Introduct...New member from FL
ADSavarese11GorillaNew Member Introduct...New member from FL
ADSavarese11Marc HNew Member Introduct...New member from FL
ADSavarese11ADSavareseNew Member Introduct...New member from FL
ADSavarese11Phu CatNew Member Introduct...New member from FL
ADSavarese11trike ladyNew Member Introduct...New member from FL
ADSavarese11Uncle FesterNew Member Introduct...New member from FL
ADSavarese11rhino 2New Member Introduct...New member from FL
Likes Likes:  2
Thanks Thanks:  1
Results 1 to 3 of 3
Thread: 2 Prong connector front of FW tank
    500+ Posts WindyOne's Avatar
    Dec 2009
    Va.
    Default 2 Prong connector front of FW tank
    I was trying to fish a charging cord under the FW tank for my phone and I found this white 2 prong connector. Purple and a yellow/black wires. Is this an accessory plug that is only hot when IGN is on? Or hot all the time? Is there a designated use for this plug?
    Wiring is not on my knowledgeable skill list so I am really in the dark here. Any help would be appreciated.
    Passing lamp wiring
    Dec 2009
    Va.
    Passing lamp wiring
    Thanks Jack
    What I ended up doing was loosening the console and slipping the charging wire under it. There is plenty of room there for one wire, then I zip tied the connecting end close to the ram mount.
  1. 3 prong charger port to Garmin Nuvi cable?
    By dannymax in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-01-2018, 08:41 AM
  2. Trailer connector - 6 prong plug
    By Backdraft in forum Stallion Trikes
    Last Post: 11-30-2013, 08:42 PM
  3. Transmission Speed Sensor Connector location
    By Craig in forum Harley Trike Conversions
    Last Post: 03-02-2013, 11:43 AM
  4. Installing MP3 player connector on GW1500SE
    By Bighank in forum Honda Trikes
    Last Post: 08-28-2012, 10:08 PM
  5. Replies: 6
    Last Post: 07-05-2012, 01:46 PM
