LD-Ordie4rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie4SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  4
Thanks Thanks:  1
Results 1 to 8 of 8
Thread: Trunk latch wiring
    Oct 2020
    Amanda, Ohio, USA
    Default Trunk latch wiring
    Hey all! Looking for information on the truck latch to make it push button open. I see the plug on the latch It has three pins. Which pin is ground and which is power? Any help is appreciated!
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    I cannot help you, but I can offer you a big Texas welcome.
    welcome aboard hey Tommy do you know
    Gene..............Welcome to Trike-Talk...................
    Oct 2020
    Amanda, Ohio, USA
    Thanks for the welcome everyone!
    Quote Originally Posted by LadyonaMission View Post
    Oct 2020
    Amanda, Ohio, USA
    Hey all just wanted to update you on the trunk latch wiring. I located a photo of the latch with the wiring on it. The first wire is ground and second is hot and I wired the negative to the ground on the trunk light. I wired the positive to a ignition circuit so that you can only release the trunk when the key is in the ignition and turned on. I placed a push button next to the interior light above the cup holder.
    150+ Posts ODDOMAN's Avatar
    Aug 2010
    EFFINGHAM, SC
    Default Trunk latch
    Quote Originally Posted by Wild Bill Bailey View Post
    You probably have your issue cleared up by now, but I did wire my latch up , connected it to the inside light switch...open the trunk, turn on the light switch then off again...popped trunk popped open...
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    can this be done to the Venture Hannigan conversion? In-laws having trouble with their truck lock is why I ask.
    2019 Goldwing CSC
  1. Trunk Latch
    By Ironhorsepilot in forum Harley Trike Conversions
    Last Post: 03-03-2022, 04:50 PM
  2. Electric trunk latch
    By ODDOMAN in forum Stallion Trikes
    Last Post: 09-09-2011, 05:57 AM
  3. Trunk Latch on 2011 TriGlide
    By OlBandit in forum Harley Tri Glide
    Last Post: 08-15-2011, 11:37 AM
  4. Basement(lower trunk) Latch
    By Triker Mike in forum Honda Trikes
    Last Post: 11-06-2010, 06:47 AM
  5. Trunk latch
    By Triker Mike in forum General Discussion
    Last Post: 04-27-2010, 03:07 AM
