Likes Likes:  2
Thanks Thanks:  1
Results 1 to 12 of 12
Thread: new avon av91
    5+ Posts
    Nov 2020
    solon,iowa usa
    Default new avon av91
    after reading post on this tire I decided to buy one. I got it today and started to look for an index mark for the valve stem ( Dunlops dot.) and didn't find one. Am I missing something?
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Quote Originally Posted by rodspinner View Post
    Just mount it & install Dyna-Beads. Works just fine. O yeah, Avon calls for 41 in the front tire
    2020 TriGlide Tahitian Teal aka (Hawaiian Hussy). Avon frt & Comfortred rear tires. ProAction frt & rear susp. RZ seat. DK floorboard extension & rear axle retainer kit with EBS, HD pull -back bars. Custom Dynamics front turn signals & Vent grill. All ,HD "Edge Cut " accessories.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Just mount it & install Dyna-Beads. Works just fine. O yeah, Avon calls for 41 in the front tire (much easier to pour in when mounting)
    200+ Posts Wmitz's Avatar
    Jun 2018
    Crossville, TN, USA
    Having that tire on my bike now with about 4K on it, watch the tire pressure. I run 38/39 no issues. If I run 41, I get a slight vibration thru the bars. It has been noted in other threads as well. Tire performs great.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Quote Originally Posted by Wmitz View Post
    hmmm, over 14k on mine & no vibration. 41 pressure. I guess whatever works. If it starts to cup,more air.
  6. DKCustoms postbit
  7. #6
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Quote Originally Posted by PosseRider View Post
    What amount of Dyna-Beads did you install? After two years and 20k, I have to replace mine. Starting stress cracks in treads from scrubbing it a lot.
    HOW CAN YOU HELP THE TRIKE TALK FORUM? Become a GOLD CLUB MEMBER!
    A veteran - whether active duty, retired, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to the 'United States of America', for an amount of 'up to and including my life.'
  8. #7
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    I dont remember Pat. Whatever the website calls for. Got a good deal on it at ebay,but that was some time ago.
    Here ya go.
    Motorcycles
    Motorcycle applications are easy for all bikes, 2 wheel or 3 wheel
    Front
    80 - 120 mm tire width
    1 oz
    80 - 120 mm tire width (BMW Telelever only)
    2 oz
    130 mm tire width
    2 oz
    Rear
    130 mm - 240 mm width
    2 oz
    250 mm - 360mm tire width
    3 oz
    195 - 205 car tires on the rear
    3 oz
    M Series Tires Sizes
    MH – use 80 mm width
    MR– use 120 mm width
    MJ– use 90 mm width
    MT– use 130 mm width
    MM– use 100 mm width
    MU– use 140 mm width
    MN or MP– use 110 mm width
    MV– use 150 mm width
    These codes are typical for Harleys but can be for any tire. The codes do not go beyond 150mm in width. With these tires, the first number of the tire size is not the actual width, it is just a number. The M-code is what tells you the actual width.
    Scooters
    10" diameter wheels (scooters)
    1 oz
    12" & Up diameter wheels (scooters)
    2 oz
    Dual Purpose / Off Road with Rim Locks
    Front - 80 - 120 mm tire width
    2 oz
    Rear - 130 -230 mm width
    3 oz
    Rim Locks - add one ounce over what you normaly use for that size tire to accomodate the additional weight of the rim lock. Two rim locks opposite each other don't require any more Dyna Beads other than stated above, as they have a tendency to cancel each other out.
  9. #8
    5+ Posts
    Nov 2020
    solon,iowa usa
    Default recall on U tube
    Thanks for all the grate info. I did see on U-tube an English speaking gent talking about a recall on av71s with cracks coming from the treads, he gave models #s and years made... Worth checking out.
  10. #9
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    If I remember correctly, the 71 was the old style & discontinued about 3 yrs ago.
  11. #10
    5+ Posts
    Nov 2020
    solon,iowa usa
    my mistake. Avon cobra Chrome tire recall. 1 week ago was posted by Revelator Alf on U tube. Found it by searching Avon tire recall. Hope this might help someone.
  12. #11
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Mine is the AV71 and yes I am starting to see cracks within the treads and it still looks like it can go another 10k after 20k already on it. Just not going to take a chance. Looks like 2oz of Dyna-Beads will do it!
  13. #12
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    That recall was from ,a year ago. Nov.of 2019. https://www.avontyres.com/en-gb/poli...e-tyre-recall/
  1. Update Avon Cobra Trike tire
    By Hocky in forum Honda Trikes
    Last Post: 12-03-2016, 11:44 AM
  2. First impression of new Avon Cobra Trike front tire
    By mhgoldwing in forum Honda Trikes
    Last Post: 08-19-2016, 06:31 AM
  3. Warning about ordering Avon trike tire
    By mhgoldwing in forum Tires, Wheels, Brakes, Front End
    Last Post: 04-29-2015, 04:22 PM
  4. avon trike tire
    By irmagoo in forum Tires, Wheels, Brakes, Front End
    Last Post: 02-19-2015, 08:48 AM
  5. Avon Cobra Trike front tire #2
    Last Post: 12-04-2014, 08:02 AM
