Likes Likes:  3
Thanks Thanks:  1
Results 1 to 3 of 3
Thread: Harley Hydraulic Clutch
    Default Harley Hydraulic Clutch
    Just for grins I bled my clutch today. I am glad I did. The master cylinder had what looked like geld dot 5 fluid. I am anal about fluids. I had already bled my system twice before the recall. It has been under 2 years since it was in the dealers shop for the recall.
    I will check the fluid again in a couple hundred miles. I urge y'all to make checking your fluid at least every oil change.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Smile
    When all Harley's used DOT5 fluid, you didn't experience these problems unless you over-washed your motorcycle. Since 2004, some use it and some don't and if you don't check the cap you aren't sure. Lord help the one that buys a used motorcycle, hard to tell what fluid was put in it.
    Jim Murphy
    Iron Butt Rider 2001
    Very good point for those that are not sure, check first so bad JU JU does not come your way I remember a friend of mine topped his off before a trip to Sturgis. Guess who did an overhaul @ the campgrounds that night? What a mess
  1. 2019 Harley Triglide Hydraulic Clutch Problems
    By Puckmeister in forum Harley Tri Glide
    Last Post: 07-09-2019, 04:50 PM
  2. Has Anyone Flushed Their Hydraulic Clutch System?
    Last Post: 01-31-2018, 07:01 PM
  3. Replies: 10
    Last Post: 10-10-2017, 06:53 PM
  4. Hydraulic clutch too hard to pull
    By Huelshorst in forum Harley Tri Glide
    Last Post: 03-17-2016, 11:49 AM
  5. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
