Likes Likes:  4
Results 1 to 7 of 7
Thread: 06 Harley Ultra Classic True duals underneath with side boards, would they fit ?
    Aug 2013
    Houston
    Default 06 Harley Ultra Classic True duals underneath with side boards, would they fit ?
    Hell Forums, just wondering if anybody have a belt driven Lemans trike with floor boards
    with true duals going underneath instead of the other type that goes over to the left side ?
    I would prefer the change it to put the extra heat at the bottom, my wife's left leg gets too hot.
    Rico.......Welcome to Trike-Talk..........I can't help on the true duals.....But i'm sure someone will chime in soon with the answer....
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Rico, Welcome to Trike Talk from West Virginia.
    The back cylinder head pipe usually sweeps out the left side on a tru-dual exhaust.
    You could probably take a set of Long Shots and make a system that looks similar to the 2009 and later.
    If you have HOG EFX boards, you may have clearance issues at the rear.
    A competent motorcycle shop should be able to help you and it would probably be a good winter project too.
    Jim
    Jim Murphy
    Iron Butt Rider 2001
    Here is what the left side of a Harley bagger with true duals looks like
    Keep in mind these systems are not cheap, good luck in your search
    Aug 2013
    Houston
    Thank You members your ideas and comments are all very much welcome,
    For the rear cylinder we have one like in the last picture, but I was wondering if
    the other type of head pipes true duals where the front head pipe go across the
    the bottom to the passenger side would work ?
    our Trike has the leman’s floor boards installed.
    Thank You
    Quote Originally Posted by ricogomez View Post
    Thank You
    It could be done by any good exhaust shop ( provided they have a good welder) but, that is not the definition of true duals to a purest
    Aug 2013
    Houston
    I looked at the S & S true duals with individual head pipes,
    but they are a bit expensive at the moment, around $450.00
    on eBay and I don’t have the funds right now.
  1. True duals, are there any gains in performance or economy?
    By engprosinc in forum Harley Trike Conversions
    Last Post: 04-14-2014, 05:51 PM
  2. 14 trike with Lift kit/ will VH dresser duals fit
    By scuba1954 in forum Harley Tri Glide
    Last Post: 11-26-2013, 04:45 PM
  3. True Duals
    By gbsb in forum Harley Trike Conversions
    Last Post: 10-01-2012, 07:47 PM
  4. '09 T/G which true duals? oil temp 250*
    By eagle1 in forum Harley Tri Glide
    Last Post: 10-10-2011, 01:29 PM
  5. true duals for tri glide?
    By rog1215 in forum Harley Trike Conversions
    Last Post: 10-29-2009, 03:46 PM
