Results 1 to 3 of 3
Thread: Fixing a flat
    600+ Posts Saltywheels's Avatar
    Oct 2009
    Rancho Palos Verdes, CA
    Default Fixing a flat
    As you folks might remember I lost a drive shaft / u-joint recently. Got me thinking hard about breakdowns. Ok, so the last incident was not a road-side fix type. But what about a flat. On 2-w, always took off the wheel & fixed it with my Pocket Fix-it & Slime pump. What do you do on a trike? How you gonna take off yr wheel to fix it Can't carry around a bottle jack on a long trip. In my limited trike experience, raising the rear end of my 03 GL took a floor jack & 2 jack stands. For some reason trying to use the floor jack under the diff just caused the bike to go up on one side. Then used a stand to hold that end up. But what do ya do on the road: Would appreciate any suggestions from the long distance gang. I've got a few multi-day trips planned & dont want to rely on chance. I just learned !@#$%^ happens. Thks
    You dont stop riding because you're getting old. You get old cause you stopped riding
    Mar 2008
    Omaha. NE USA
    Default Re: Fixing a flat
    I carry a crescent shaped device used for Jet Ski and boat trailers. They come in two sizes and the smaller one might work in a some cases. The design allows you to place a corner of the device under a frame or axle then you drive forward or backward to allow the crescent shape lift the Trike up as the curved nature will contact the road surface. I have not tried this and hope it might work on my stiff riding '04 Lehman with a solid axle. With a flat and running boards this is going to be tough. Maybe one of you people with too much time on your hands can design something like this that would be smaller. Here's a link to the Watercraft Superstore. Trailer Jack, Easy Lift | Winches & Jacks | Watercraft Superstore.
    I also carry the Stop-N-Go tire plug gun with CO2 cartridges. Never used that on mine but did on another riders two-wheeler.
    Contrinuting Member
    Apr 2009
    greenfield indiana
    I carry a air commpreser I bought at walmart for less the twenty dollars plus some tire plugs and a can of fix a flat.
    Of course I also carry a set of battrey cables,a small metric socket set I bought at sears on sale for 12 dollars,a allen wrench set some duct tape,some black elec. tape and a small amount of 14 gauge elec.wire along with the orignal tool box and tools plus a small fire extingsher.
    You know the boy scout moto be prepared,also I have the gwrra rescue plan,also my foremost insurance plan has a towing and road side assitance plan.
    I have used the gwrra. rescue plan twice,once for the motorcycle when the fuel pump went bad tow truck was there in 15 min.
    Once with the car,I paid that one and then sent the bill to gw. and they reimbursed me.
  1. Oh them big flat rear tires
    By the paparazzi in forum Tires, Wheels, Brakes, Front End
    Last Post: 07-06-2016, 09:55 PM
  2. Flat bed trailer to tow Trike?
    By NEMO in forum Trailers / Campers
    Last Post: 07-02-2013, 01:18 PM
  3. Fixing Reverse
    By cruderanger in forum Harley Trike Conversions
    Last Post: 02-19-2013, 02:06 AM
  4. Flat tire preparation
    By Al Killeen in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-20-2011, 10:07 PM
  5. flat tire
    By oldmanonavtx in forum Outrigger Style Trikes
    Last Post: 06-29-2011, 10:43 PM
