Likes Likes:  189
Thanks Thanks:  13
Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 121 to 140 of 145
Thread: TriPod
  1. #121
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default Flasher
    Name:  2021-09-14-4090 Tail flasher.jpg
Size:  726.3 KBWires the flasher, Possible buyer came by this morning,And ready the full 48 Volts, F-R, Speeds 1-2-3 wires,
    JakeJacobsen@Pinterest.com
  2. #122
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
  3. #123
    May 2016
    Hemet, Ca. USA
    Default Closer
    Name:  2021-09-15-4092 Button up J-Boxs.jpg
Size:  732.1 KBButtoned up the J-Boxes, rear flasher lights work good and the horn is way to loud,
  4. #124
    May 2016
    Hemet, Ca. USA
    Default More soon-
    Name:  2021-09-16-4098 Low Batts.jpg
Size:  642.8 KBCharge Batts-Name:  2021-09-16-4099 Almost Ready-.JPG
Size:  919.9 KB-More soon-er,
  5. #125
    May 2016
    Hemet, Ca. USA
    Default Moving
    Should be moving this week, then this thing will be going to a wiring pro, ...
  6. #126
    May 2016
    Hemet, Ca. USA
    Default TriPod
Size:  828.6 KBMoving sucks, the plumbing, Ducts come apart, carport is still not enclosed, but the hell with it, TriPod is going in for the wiring fix this week,
  7. #127
    May 2016
    Hemet, Ca. USA
    Default TriPod
    Sometimes things don't according to plan, such as the new house with many problems, and the wiring didn't turn out the way the instructions noted (Damn Chinese)Name:  2022-07-25-271.JPG
Size:  910.4 KBand the heat here in Riverside so I take it apart and move the electrics inside,Name:  2022-07-25-270.jpg
Size:  827.5 KBand with the help from YouTube wiring problems solved,Bench Tested that is, now to put it back on the trike to find the mistakes...
  8. #128
    May 2016
    Hemet, Ca. USA
    Default TriPod
Size:  845.0 KBColor coded wires mixed up from controller to twist grip,forward and reverse are mixed on the selector (minor fix)then bolt down the engine+ chain and GO-GO, I hope...
  9. #129
    Thumbs up
    Good 2 C U back at it, still following
  10. #130
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Yep, still following you Tommy, taking shape at last.
  11. #131
    May 2016
    Hemet, Ca. USA
    Default Wiring
Size:  808.0 KBThis is my so-called wiring from a pro, and I paid for this shit...
  12. #132
    Quote Originally Posted by TomyJ View Post
    That is ugly from a pro, I would expect to see soldered joints with heat shrink @ the very least from a pro
  13. #133
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    The real pro is the man in the mirror....you will have to wire it yourself...
  14. #134
    May 2016
    Hemet, Ca. USA
    Default wiring
Size:  845.0 KBSetting up the wiring now on the trike (note the batts). OK!The wires were mixed from the controller to the throttle (Thanks China) AND!!! I found a local wiring/solder guy who helps restore old pin ball machines locally, How cool is that... After he fixes TriPod then he will do RebelRouser.
  15. #135
    May 2016
    Hemet, Ca. USA
    Default Projects
    I am not destined to get the projects finished,The wiring guy's wife gave him covid, so I decided to do one of my "Honey Do's List" change the double side stairs for more room in the carport. Name:  HPIM4284.JPG
  16. #136
    May 2016
    Hemet, Ca. USA
    Default Batteries rewire
    Name:  2022-09-22 Batteries wires.jpg
Size:  874.4 KBBatteries rewire, Still at it, a little at a time...
  17. #137
    May 2016
    Hemet, Ca. USA
    Default Mock up again
    MockUp again! DAMN! Most of the wiring is straightened out BUT when the motor is engaged the diamond plate moves up or down, not enough support/bracing for the motor mount plate, so back to the drawing board for more bracing...Name:  HPIM4317.JPG
Size:  846.2 KBName:  HPIM4318.JPG
Size:  943.9 KBName:  HPIM4319.JPG
  18. #138
    May 2016
    Hemet, Ca. USA
    Default MotorMount
Size:  821.6 KB-Name:  HPIM4331.jpg
Size:  847.9 KBDo you think these added braces will stop the flex? EDIT: Have to order the aluminum from eBay, not a large supply here in Hemet Ca.
  19. #139
    Yes, nice job with the fab and welding
  20. #140
    May 2016
    Hemet, Ca. USA
    Default Motor support
    Name:  2022-10-30 Torque Support.JPG
Size:  928.8 KBThe welder said this is over kill, I hope he's right.
