Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  0
Results 1 to 17 of 17
Thread: Help with new carb.
    40+ Posts vwjoe's Avatar
    Mar 2011
    Oak Lawn Illinois
    Default Help with new carb.
    Hello again i got the engine all together i tried to start, it is back firing and will not start at all. I now it has to be the carb. the carb is a brand new 34 pict it has two stouts for vacum lines. Am i supposed to run a vacum line from the distributer to it or no. and how do i set all the screws for start up. then i can adjust. any help please.
    2500+ Posts Ozarkryder's Avatar
    Feb 2008
    Anderson, Missouri
    Default Re: Help with new carb.
    We had a Dell'Orto DRLA on The Blue Trike, never had any dealings with the Pict. But - get yourself down to the nearest bookstore and pick up the "Idiot Book".
    Any air-cooled VW owner, whether Bug, Ghia, Squareback, Sandrail or Trike should have this manual even if they have others. Not only does it give step by step procedures for fixing a VW, it is a hoot to read. Was written by an ex-NASA engineer turned hippy, so it has a great 60's attitude and style. The drawings are amazing, and very clear.
    You may be able to get it at a 2nd hand or vintage bookstore used, or at places like Amazon.
    Here is a link for info from Amazon-
    Amazon.com: How to Keep Your Volkswagen Alive 19 Ed: A Manual of Step-by-Step Procedures for the Compleat Idiot (9781566913102): John Muir, Tosh Gregg, Peter Aschwanden: Books
    Don - 2004 GL1800 Champion trike, 2018 Can Am Spyder RT Limited
    2 wheeler: 2013 Triumph Bonneville T100
    FORR Local 11, AMA, MRF, Mid-South MILE Committee
    300+ Posts
    Mar 2011
    Tucson, AZ USA
    Not familiar with the Pict carb, but typed in "34 pict carb" on Bing and found these 2 links that might help:
    SOLEX 34 PICT/3 Carburetor Adjustment Procedures
    SOLEX 34 PICT 3 CARBURETOR ADJUSTMENT AND TUNE-UP PROCEDURES
    Mar 2011
    Oak Lawn Illinois
    ok ordered the idiots book. thanks for the sites i did all that already. i put the old carb back on i new it worked but its old so i figured go new. now i am getting fuel and its timed but it still will not start. number one plugs let out a poof and then the motor just cranks and cranks. compression is 130 to 135 all plugs are new an proper gapped and new wires and coil. but still nothing.
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Quote Originally Posted by vwjoe View Post
    I can not remember because it's been 20 years since I worked on VW's is it possible to put the distributer in 180 degrees out? If so might be the cause.
  6. #6
    Mar 2011
    Oak Lawn Illinois
    Yes it is but i checked that and it is in correct and timed correctly also.
  7. #7
    TOI - Oklahoma Frozenshrimp's Avatar
    Sep 2010
    Edmond,Ok USA
    Joe, I have the book for idiots like myself first make sure that you have the plug wires in the rite firing order not saying that you don't! take the distributor off and on the housing you will find a small notch that is the number one firing position going clockwize the order is 1,4,3,2 the larger notch is for the distibutor cap. Hope this helps!!
    Sean
    Sean Church
    Edmond, Ok
    VW Trike :wave4:
    TOI Oklahoma Chapter Contact
    EMail:frozenshrimp@cox.net
  8. #8
    Mar 2011
    Oak Lawn Illinois
    Quote Originally Posted by Frozenshrimp View Post
    Sean
    Okay thank you to everyone but you all were wrong. lol I had everything correct but the boot around the head pipe was busted and what happened was it created a back flow vacum leak. it was so bad that it would just leak all fuel out before hitting the cylinders. I am not sure how i figured it out it was a lucky catch i think. But Thank you all sincerly for the help. I hope this information may help someone else about ready to c4 there trike.lol. Here is links to the build project photos and also the video i just shot of the engine starting today. I just has to run in and share with trike talk. This place is awesome. Thanks again everyone.
    Link to photos of the build.
    https://picasaweb.google.com/1020850...keBuildPhotos#
    Video of the new engine Running..
  9. #9
    Sep 2010
    Edmond,Ok USA
    Excelemt news vwjoe,would have never thought of looking for that. Sounds good can't wait till its all together...Again excelent news!!!
    Sean Church
    Edmond, Ok
    VW Trike :wave4:
  10. #10
    1250+ Posts katfish16's Avatar
    Feb 2008
    Gallion, Alabama
    Joe, I once bought a VW from a guy who had spent all winter building the engine,, did a great job.. he put the engine in and could not get it to crank..he then decided to sell it.. I got it and found out that he had cut the points wire when he put the Dist. cap. on that is why it would not crank.... so I installed new points and it cranked right up...
    Called the guy and offered to sell it back to him, for what I got it for.. he was so mad he did not want it back....
    Vw's sometimes would make the Pope cuss....
    Glad U found ur problem...
    Steve & Cathy
    Alabama
    U.S. Coast Guard (retired)
  11. #11
    Mar 2011
    Oak Lawn Illinois
    Yea I never thought of it either if I fix not see the fuel leaking I would not of either. Thanks yea I so bad wanna ride it. Been two years building it.
  12. #12
    Mar 2011
    Oak Lawn Illinois
    Quote Originally Posted by katfish16 View Post
    Lol that so sucks for him. Yea I think I would of been pissed to. Ok I feel a little better. I have a new fire now that I got it started so now rolling foward more pics to come hope to be on it in a couple of months.
  13. #13
    TOI -Virginia KDHUFF's Avatar
    Feb 2010
    millboro, va
    gotta love that throttle cable. gonna run that over the shoulder or under when the trike is finished, .......joking of course, we have all done that at one time or other.
  14. #14
    Mar 2011
    Oak Lawn Illinois
    Quote Originally Posted by KDHUFF View Post
    I was gonna duck tape it to seat and just reach around for The throttle or if I have a passenger in back they can work it. Lol be like team work. No seriously I'm going to tie around the front handle bars and push an pull for throttle lol. Ok no it will run down a tube I am going install by The shifter rod to The foward controls all under The frame.
  15. #15
    80+ Posts Buggie Pilot's Avatar
    Mar 2010
    Stafford Springs,Ct.
    Joe ... you can find out almost anything if not everything about VW's at this forum The Samba
    [SIGPIC][/SIGPIC]
    Honored to be a member of the
    Connecticut Patriot Guard
    Pete G
  16. #16
    Mar 2011
    Oak Lawn Illinois
    Quote Originally Posted by Buggie Pilot View Post
    Thanks biggie I also belong to that site.
  17. #17
    Mar 2011
    Oak Lawn Illinois
    Oh yea I forgot I also posted triketalk.com all over in there. Lol.
  1. Carb Q&A
    By Doug D. in forum VW Powered Trikes
    Last Post: 02-15-2016, 12:41 PM
  2. p 34 carb?
    By skeeter in forum VW Powered Trikes
    Last Post: 06-29-2012, 10:51 AM
  3. CV carb problem
    By Jax in forum Harley Trike Conversions
    Last Post: 06-14-2012, 07:19 PM
  4. What kind of carb is this?
    By donnie850 in forum VW Powered Trikes
    Last Post: 08-05-2011, 12:57 PM
  5. Carb cleaning
    By John Luciano in forum General Discussion
    Last Post: 03-17-2011, 08:28 PM
