ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Likes Likes:  6
Thanks Thanks:  4
Results 1 to 8 of 8
Thread: Will a Torque cam (SE 447) increase or decrease my fuel economy
    350+ Posts
    Aug 2020
    Monaca, Pa, USA
    Default Will a Torque cam (SE 447) increase or decrease my fuel economy
    Just checking to see if I can expect decrease or increase in MPG.
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Since winter has set in here I cant report on the S&S 465 cam I had put in my 17,hoping that with the increase in power and torque I gained it will take less throttle to get moving. If I lose some mileage then so be it.
    350+ Posts
    Aug 2020
    Monaca, Pa, USA
    I’ m sure a lot depends on how you drive it. But keeping everything equal on how I use throttle from stock to cam I was wondering what to expect on my mpg.
    You probably will not notice a gain in MPG unless a qualified tuner runs a leaner mixture during dyno time, but that would be counter productive IMO
    200+ Posts Wmitz's Avatar
    Jun 2018
    Crossville, TN, USA
    I think Jack hit on the head. Again it’s not just the cam, it is the combination of parts that will make the biggest bang for the buck. The exhaust is a major component. To much resistance you lose potential power, overflowing you lose bottom end and have to twist the throttle more to get the response you looking for. There are better cams in the aftermarket, as the 447 is a epa compliant cam, but if warranty is the issue than you are very limited.
    60+ Posts
    Jan 2018
    Milton Mills NH
    I put Andrews 57H in my 103, gained tons of tq and passing power. No noticeable loss of fuel milage. More power equals less throttle.
    Quote Originally Posted by BKtrike View Post
    If you put a Cam to increase power or for that matter anything else to increase power then Human Nature will Naturally click in and you will use that extra power which will in-turn cause a reduction of MPG.........
    30+ Posts
    Dec 2020
    Seabrook, SC, USA
    Quote Originally Posted by Wmitz View Post
    Decrease. You are gonna have so much fun with the upgrade you won't care.
  1. Harley Davidson New Stage 2 Torque Cam
    By pflatout in forum Harley Tri Glide
    Last Post: 02-16-2019, 06:55 AM
  2. Help.... Shock air pressure won't decrease
    By Trikindan in forum Honda Trikes
    Last Post: 01-19-2015, 07:42 PM
  3. To cam or not to cam
    By engprosinc in forum Harley Trike Conversions
    Last Post: 04-07-2014, 10:38 AM
  4. Gas mileage decrease
    By Greydog in forum Harley Trike Conversions
    Last Post: 01-25-2010, 12:06 PM
  5. What fuel economy is normal for a trike?
    By hepengr in forum General Discussion
    Last Post: 01-23-2010, 03:39 PM
