JTJersey3Jack KlarichHarley Freewheeler /...Removing Trim Around Oil Cooler
JTJersey3JTJerseyHarley Freewheeler /...Removing Trim Around Oil Cooler
JTJersey3rhino 2Harley Freewheeler /...Removing Trim Around Oil Cooler
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Grandpot9tourmanHonda TrikesFront tire?
AriNV13Marc HNew Member Introduct...New to trike
Burnerboy4pawsRoadsmith Trikes
Too Pa Pa Zook
AriNV13Uncle FesterNew Member Introduct...New to trike
Jack Klarich2Jack KlarichGeneral DiscussionMY first guitar
Jack Klarich2ZammyGeneral DiscussionMY first guitar
Too Pa Pa Zook
Hdsteal4Jack KlarichSuzuki - Kawasaki Tr...Completed MS Trike Pics
Noodles1078Jack KlarichHarley Freewheeler /...Very Nice Gloves
Noodles1078Papa ZookHarley Freewheeler /...Very Nice Gloves
Thanks Thanks:  3
Results 1 to 7 of 7
Thread: CSC rear suspension
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Default CSC rear suspension
    The CSC rear suspension can be highly adjusted to personal riding. The best place to start is by looking at the CSC installation instructions readily available on line. My research was done with a Honda Goldwing Kit in mind so other models may be different. The kit I have has only one shock absorber mounted horizontally between the IRS. That shock can be ordered in different spring rates.
    In addition, the spring can be adjusted in length to accommodate lighter or heavier normal loads. The CSC kit retains the OEM rear shock pre load adjustment to fine tune the shock. I also understand that there is a sway bar option that, I think, may even eliminate the sway bar if hard cornering is not important in favor of a softer ride.
    The rear suspension on my bike was set up while the body was removed. I don't know for sure if it can be accessed by just removing the top box or anything else. Maybe someone from CSC can chime in and correct me or add additional information..... Jim
    2014 CanAm Spyder RTL SOLD
    Semper Fi
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Default Kit Installer
    Did you have the kit installed down in the Valley area?
    Is so what or who is CSC installer down there?
    Would like to have someone look at ours and give us some thoughts/ideas on what if anything we could do it smooth it out a little bit.
    It isn't bad but on some roads it can feel choppy. Played with the settings on the left side but that doesn't change it very much so it seems. So wondering if they put in a too heavy of a spring or not heavy enough?
    I know the setting switch works as it was checked over when we bought it.
    Can't wait for the call that the Trike is done with the Traxxion springs installed. That will make a big difference also. He is also installing Rocky's Comfort Risers, so we will be able to fully use our backrest on our Trike.
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    I have limited knowledge as my Viper is the first trike I have owned and ridden regularly. But when I had my conversion done back in mid 2016, I decided to go with their standard spring as well as the passenger comfort anti sway bar. My installer wasn't aware of it until I requested it for my kit. I was told that I was one of the first to have it done. After conversion was done, the owner took my trike on a short test drive and was pretty happy with it. In fact, he mentioned that he was probably going to recommend it on all future installs.
    The price difference wasn't much as compared to the cost of the conversion. I did test drive another trike he had there with the regular sway bar and then rode mine. I did like the passenger comfort one as well. As far as specifics, I am right around 190lbs and usually ride solo. I will usually ride with the oem suspension setting at around 10-12. I do sometimes pull a homemade cargo trailer or my Aspen Classic pop up camper. Especially when pulling the camper, I will bump the suspension setting up to 20-25 but still rides decently. Also when doing twisties, I will also bump it up above the 12 I usually use as well. My suggestion is to try and test drive a CSC with standard sway bar as well as one with passenger comfort option. It is a personal choice but you won't know until you ride both.
    Just to add, I also played with tire pressures to help get the ride comfort to where I wanted. I run about 22psi in rear tires and 36-38 in my Michelin Pilot Activ front. My MPA is almost ready to get changed and I have an Avon Cobra Chrome AV-91 Trike tire ready to be swapped out. I'm curious to see how this will ride but will have to wait until the weather cooperates...
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Quote Originally Posted by BrokenBackJack View Post
    There are 2 places here in the valley that do good trike work. They are American Bike and Trike. and the other is D&D Discount Motorcycles. D&D is also the owners of Champion Trikes. My bike was already triked when I bought it. D&D did the work for me. I have been doing business with them for many years. The web site for American B&T says they are authorized CSC dealers/installers. I have been to their store and they have some very impressive vehicles. But I have not personally done business with them other than having questions answered. When I was considering having my previous GL1800 triked, they were very open and provided good information that helped me make my decision.
    The other thing I would suggest is to call CSC directly with your concerns. I had occasion to talk with them a few months ago and found them to be very helpful and responsive. Good luck..... Jim
    Semper Fi
    Feb 2017
    Payson, AZ USA
    I will have to ask D&D about it the next time I am in there.
    Johnny 7
    Feb 2017
    Payson, AZ USA
    Default Adding oil to rear shock
    Was looking yesterday and thinking about adding oil to the rear shock as ours doesn't do anything until 10-11 on the gauge. Looks to me that the rear fenders of the trike kit have to come off to get to the part that you have to take off to add the oil to.
    Well my body isn't going to allow me to do that!
    Johnny 7
    1500+ Posts
    Oct 2012
    Batavia Ohio
    I've had 2 Wings with CSC kits and one Wing with a Hannigan kit. The only complaint I have ever had with CSC is that damn mono shock. Hannitgan's suspension is no doubt superior and I wish CSC would fix that issue. Other then that I love the CSC kit and the fact that the it has back up lights and lights underneath when the turn signals are engaged.
  1. Replies: 0
    Last Post: 09-19-2019, 08:32 AM
  2. Help tuning suspension, 98 Valkyrie/CSC
    By Tubal Cain in forum Honda Trikes
    Last Post: 08-11-2013, 09:39 PM
  3. TriGlide Suspension Upgrade By Progressive Suspension
    By JohnC in forum Harley Tri Glide
    Last Post: 02-22-2012, 05:22 PM
  4. Which is best the Champion Independent Suspension or Solid Suspension.
    By glawrence7 in forum New Member Introductions
    Last Post: 11-24-2010, 12:00 AM
