Likes Likes:  2
Results 1 to 7 of 7
Thread: Rubber Foot Peg Replacement
    60+ Posts Tony8's Avatar
    Nov 2017
    Avon,Ohio USA
    Default Rubber Foot Peg Replacement
    Need to replace the left side stock rubber on the foot peg. Moving my foot to shift has worn out the rubber on the step.
    2016 GL1800 Trike. For the life of me I cannot get the old rubber off. Any hints or suggestions?
    Thank you.
    20+ Posts
    Feb 2016
    Newton Falls,Ohio,USA
    Default foot peg
    I had no trouble changing mine, took out the two screws in the bottom of step, removed assembly from step , removed rubber from mounting plate and reversed order to reassemble.
    Nov 2017
    Avon,Ohio USA
    Hey John, that's what I thought. My son in law thinks I was using too big of a socket. It was just spinning around over the head. I have a hard time kneeling down (bad hip) and thought I was using the correct size socket--evidentially I wasn't.
    He's going to bring over his socket set and take a look at it for me. Lord have mercy--it's hell to get old. lol
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Default Been down that trail too
    Getting old and crippled, been down that trail myself for a few years now.
    Good luck with your project.
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
    Nov 2017
    Avon,Ohio USA
    Quote Originally Posted by BrokenBackJack View Post
    Thank you!
    Apr 2010
    Shenandoah Valley of Virginia
    Quote Originally Posted by Tony8 View Post
    H ... etc ... Lord have mercy--it's hell to get old. lol
    Sure beats the alternative
    Nov 2017
    Avon,Ohio USA
    Finally got around to changing the rubber on the foot pedal. Once I had the correct socket size it was a piece of cake.
  1. Change foot peg / brake location?
    By smilinjohn in forum Can Am Spyder Trikes
    Last Post: 03-31-2015, 05:09 PM
  2. gl1800 foot peg brackets
    By Iron horse in forum Honda Trikes
    Last Post: 10-24-2014, 07:38 PM
  3. Foot Peg Postion on a Goldwing
    By KRUZR in forum Honda Trikes
    Last Post: 08-20-2013, 07:43 AM
  4. foot peg for yamaha trikes
    By jhennan in forum Yamaha Trikes
    Last Post: 03-20-2012, 10:09 PM
