Likes Likes:  1
Results 1 to 15 of 15
Thread: WHIM and Harley branded Sena 20s on 2019 Triglide
    40+ Posts
    Feb 2020
    Yantis, Texas USA
    Default WHIM and Harley branded Sena 20s on 2019 Triglide
    For those of you who have a 2019 Tri Glide, if you have had a WHIM installed and have the Harley branded Sena 20S headsets how would you rate it? 1) Does it work seamlessly with the 6.5 Boom and work with all its features? 2) Does the intercom work well with the passenger? 3) Can you use Apple Car Play? 4) How is the sound of the speakers? 5) With a 2019 model did you need the harness in addition to the WHIM? 6) Does the wind noise break VOX very often or can you set the VOX to where the wind noise does not break VOX but yet your voice will when communicating to the passenger? ( I find the VOX very difficult to find the sweet sot on my Tri Gilde) 7) Any other points you want to add that I have missed would be great.
    My current set up is a wired one using EdSets headsets and unfortunately Ed is no longer in business. I also have a Freedom Shield windshield so the wind is really blocked well. I am considering going to a wireless system so we are not tethered. The wife and I both have full faced Nolan helmets which we both really like. I appreciate all input and sorry for all the questions but each of them are important points considering the cost to make such a change. Thanks everyone.
    40+ Posts
    Feb 2021
    El Paso, TX USA
    Default Torc T28's
    Sorry, I can't speak directly to your questions but I have a '21 with two Torc 28s. I haven't devoted a ton of brain cells to the set up but I will say that the intercom doesn't play well with playing music and the sound quality is not that great. The volume is good even at 75-80 but it sounds like someone dropped some headphones in an empty coke can.
    Quote Originally Posted by Tres Huevos View Post
    Paul..........Welcome To Trike-Talk...........
    40+ Posts
    Feb 2021
    El Paso, TX USA
    Default Thanks!
    Thank you I appreciate the welcome
    Dec 2013
    Clarion PA USA
    I'll keep tabs on this thread the bride 👰 and I are going to be going wireless in the spring and errands welcome to the forum from Western Pennsylvania. Travel safe Fred
    40+ Posts Rider70's Avatar
    Jun 2019
    Gettysburg, PA, USA
    I had a WHIM installed at purchase of my 2019, and had the Harley 30Ks already. I will say the stereo is nice. There is some wind noise on VOX if not set right and the PAX is soft spoken. That said, very happy with ours. We enjoy chatting while seeing the country side go by. No freeways for us.
    40+ Posts
    Feb 2020
    Yantis, Texas USA
    Quote Originally Posted by Rider70 View Post
    Thanks Rider70 for your opinion. I guess the VOX issue is going to be a problem regardless of wired or not. I wish Harley would improve that issue with their infotainment units. We wear full faced helments and have our mic angled upward and still have the issue. You either have the music cutting in and out or have the VOX set so low you have to yell into the mic to use the intercom. Frustrating to say the least. It was that way on our 2009 Ultra Classic too.
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Quote Originally Posted by osudvm View Post
    We use wired J&M headsets with HJC modular helmets. Vox works OK as long as there is very little wind. However if the wind picks up and especially gusts the we have the same vox problems you described . . . and have had on many of our various HDs but the models with the Boom Box seem to be worse than the older Harmon Kardon radios.
    40+ Posts
    Feb 2020
    Yantis, Texas USA
    Quote Originally Posted by ultrafxr View Post
    Thanks for the feedback. We had the older HK on the 2009 Ultra Classic and I agree that the Boom is worse (or more sensitive) than the HK units. Seems that issue could be easily solved but maybe I am expecting too much. I also agree with the gusts really messing it up. Especially when the gusts comes from the sides of the helmet. Our full faced Nolan helmets are fantastic and provide a lot of wind buffeting but we still have issues.
  11. #10
    150+ Posts windsurfed's Avatar
    Jul 2020
    Spokane WA USA
    Default Whim installed here
    I have the whim and the HD Sena 20s headsets on our 2020 TG. We use 3/4 open face helmets. Car play works good. Siri works better. Phone calls are fantastic. Radio works great. All this works only if you are connected to the boom box 6.5 thru your sena headsets. If you are not connected with the sena, car play will not work. I am extremely happy with the whim and Sena setup. Bike to bike com is fantastic. No wind interference in any of the above mention things. Just using the supplied wind socks from sena.
    Stupid is a choice
    Dumb is not a choice
    Stupid can be fixed
    Dumb cannot be fixed.
  12. #11
    40+ Posts
    Feb 2020
    Yantis, Texas USA
    Quote Originally Posted by windsurfed View Post
    Thanks windsurfed. Sounds like you have found the HD Sena20s to work quite well with the WHIM. Those are all the things I want it to do that you listed. I use Carplay and Siri all the time now with our wired system. We only need the intercom to work between the wife as a passenger and me driving and not bike to bike. Were the Senas hard to install in your helmets? I hope my EdSets can easily be removed from our Nolan helmets.
    One other question, when you have all of this setup, do you still use (press) the voice command button to ask Siri to perform functions with the Boom Box.
  13. #12
    Jul 2020
    Spokane WA USA
    Default Answer to question
    We also have Nolan Helmets. Very easy to install the sena's. Yes you just use the voice command button to activate Siri. Works like a champ. It does every thing you would expect it to do. Before I had the whim installed I used the HD headset like yourself. Anything you can do with your HD headset can be performed now with the whim/HD sena 20s evo set up. The only difference is you are not tethered anymore to the HD dedicated Communication port plugs. And your pocket book will be a lot lighter.
    Stupid is a choice
    Stupid can be fixed
  14. #13
    40+ Posts
    Feb 2020
    Yantis, Texas USA
    Thanks again. Sounds like a great setup. I hear you on the pocket book. I figure to buy two headsets, the WHIM, and get the WHIM installed at the HD dealership (I will not do it myself) and then get the unit flashed, will set me back about $1500.
  15. #14
    Jul 2020
    Spokane WA USA
    Just looking at my cost from the Dealer. I only bought 1 head set from the dealer. Bought the other one brand new off eBay from a gentlemen that just bought a TG CVO and they give one with it and he did not need it. I got it for $187. So........ Dealer Sena $299+Whim $299+Labor install $157.50+ Tax $67.84+ Ebay Sena $187=$1010.34. I am a thinking you should get all that for around the same price.
    Stupid is a choice
    Stupid can be fixed
  16. #15
    20+ Posts
    Jun 2020
    PHOENIX, AZ 85022
    Installing the WHIM on the tri glide is easy. I did a video after the install but I also did one on the Road Glide a bit more detailed. I have the HD Sena 20s EVO's and they work great. You will also want to upgrade the helmet speakers with the new Sena HD speakers. I also made a quick video on that.
  17. DKCustoms postbit
  1. Communications 20s or 20s EVO
    By NC Triker in forum Harley Tri Glide
    Last Post: 03-03-2018, 11:00 AM
  2. WHIM and HD 20S EVO Info
    By MDF48 in forum Harley Tri Glide
    Last Post: 02-05-2018, 11:01 PM
  3. sena 20s
    By Lund150 in forum General Discussion
    Last Post: 10-09-2016, 09:16 PM
  4. SENA 20s head sets
    By hotrodbob in forum Harley Freewheeler / Road Glide 3
    Last Post: 05-05-2016, 07:19 AM
  5. Sena 20S Intercom
    By Gorilla in forum General Discussion
    Last Post: 04-23-2016, 03:28 PM
