JTJersey3Jack KlarichHarley Freewheeler /...Removing Trim Around Oil Cooler
JTJersey3JTJerseyHarley Freewheeler /...Removing Trim Around Oil Cooler
JTJersey3rhino 2Harley Freewheeler /...Removing Trim Around Oil Cooler
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Grandpot9tourmanHonda TrikesFront tire?
AriNV13Marc HNew Member Introduct...New to trike
Burnerboy4pawsRoadsmith Trikes
Too Pa Pa Zook
AriNV13Uncle FesterNew Member Introduct...New to trike
Jack Klarich2Jack KlarichGeneral DiscussionMY first guitar
Jack Klarich2ZammyGeneral DiscussionMY first guitar
Too Pa Pa Zook
Hdsteal4Jack KlarichSuzuki - Kawasaki Tr...Completed MS Trike Pics
Noodles1078Jack KlarichHarley Freewheeler /...Very Nice Gloves
Noodles1078Papa ZookHarley Freewheeler /...Very Nice Gloves
Likes Likes:  9
Results 1 to 8 of 8
Thread: My Road King Project
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Default My Road King Project
    Just got back from the shop, my big bore cylinders and pistons came in so just waiting for my cylinder head guy to finish my heads then I can tear ole red down to make it a 95 incher.
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    That is a great start!
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Looking forward to following this Steve.
    1500+ Posts
    Apr 2016
    Dayton Ohio
    The last 95 inch I did had small cams .508 lift, 9.5 compression and the heads were ported and flowed with stock valves and it had the old style Magnetti Marelli injection. And it made 101 hp and 112 ft lbs torque. These new heads will have large intakes and stock exhaust valves but it will end up at about 10-1. The cams I'm running in this bike are Woods 408-48 not much more lift than the last build but higher duration which will work good with the big valve heads. Hoping to have hp in the low teens.
    I would assume you will be upgrading the cam tensioners? This started life as a 88 TC? My kid brother in Arizona has a Screaming Eagle 95 inch TC bagger. I rode it a few years back on the way to Sturgis. It had balls. The only downer on his build was the tech did not upgrade the useless factory spring loaded tensioner.
    1500+ Posts
    Apr 2016
    Dayton Ohio
    When I first got this bike the tensioners were shot so I replaced them, but didn't do the upgrade because I wasn't sure the cams I got would be the right ones. So the new cam plate and oil pump is on the list when I do the tear down. I have another set of cams I may install when I get the heads back and look at the flow chart.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Steve, years back when I did my 03 gear drive, I used Feuling plate & pump. over 100k on that bike when I sold it & never missed a beat. I have a couple throttle body's 500 miles on each with all sensors if you have a need for one. Not Magnetti Marelli. The good one.
    1500+ Posts
    Apr 2016
    Dayton Ohio
    Posse Rider I appreciate it but this bike is carbureted and I have a S&S with a Thunder Jet 3rd fuel circuit so I am pretty well set. With heads ,pistons and new cylinders I will have less than $1500 including gaskets, my buddy gave me the S&S I just had to put a rebuild kit in it.
  1. Road King Classic Conversion
    By IanATL in forum Harley Trike Conversions
    Last Post: 03-30-2011, 08:44 AM
  2. speakers for road king trike
    By ecke877 in forum General Discussion
    Last Post: 01-06-2010, 10:49 PM
  3. Thinking of triking a 2009 Police Road King
    By CRBandit in forum Harley Trike Conversions
    Last Post: 12-24-2009, 01:24 PM
  4. Road King Conversion to Trike
    By trickyrick55 in forum Harley Trike Conversions
    Last Post: 10-13-2009, 06:28 PM
