Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  5
Thanks Thanks:  1
Results 1 to 5 of 5
Thread: Lehman trike conversion question 2011 harley ultra limited
    Jul 2019
    Surprise, AZ, USA
    Default Lehman trike conversion question 2011 harley ultra limited
    Im looking at purchasing a 2011 harley ultra limited that has a lehman trike conversion done to it what things should i be looking out for things to check etc thanks for any and all information
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Quote Originally Posted by PGLGHDBLDR View Post
    Rick,
    If it has Wilwood rear disc brakes, make sure that the rear differential has been greased regularly.
    Most of the rear components are available but that particular differential does require greasing.
    The body transition panels (elephant ears) are prone to coming loose, so you should have a security strap added so that you don't lose it or it doesn't get removed when you aren't looking.
    Jim Murphy
    Iron Butt Rider 2001
    Jul 2019
    Surprise, AZ, USA
    The kit is a Lehman Trinity LLS and I am trying to figure out what brake pads they use as it doesn't look like the brakes are wilwood I was told its actually a Champion rear end and uses a VW brake pads
    Martinsburg, WV
    Cool
    The Trinity (looks like a tri-glide) is IRS rear suspension with champion undercarriage. If the calipers look like VW calipers, it is 99% Champion. Not knowing the year that the Kit was manufactured (2012, 2013 or later) it is hard to identify the brake system Lehman used prior to Champion without pictures. Could be a couple different types. Does it have a parking brake ?
    Jim Murphy
    Jul 2019
    Surprise, AZ, USA
    It does have a parking brake on the right side if you sitting on the bike I do believe it is VW brakes on this trike I also need to get the Parking brake adjusted as you have to pull it to the max to get it to hold I feel it probably needs brake pads and a parking brake adjustment the tag on the swing arm is stamped with a 2016 date code along with some other numbers before it
  1. Replies: 23
    Last Post: 11-03-2021, 09:16 AM
  2. Triking my 2011 Ultra Limited
    By houronron in forum Harley Trike Conversions
    Last Post: 06-23-2020, 05:42 AM
  3. Road Smith Harley Ultra Limited
    By 14 trike in forum Roadsmith Trikes
    Owners Forum
    Last Post: 05-11-2019, 08:14 PM
  4. Conversion for 2014 Ultra Limited
    By RatRodMan in forum Harley Trike Conversions
    Last Post: 11-14-2017, 04:23 PM
  5. Lehman trike conversion 2005 Ultra
    By engprosinc in forum Harley Trike Conversions
    Last Post: 06-13-2013, 11:48 AM
