Results 1 to 3 of 3
Thread: Champion IRS Shock Adjustment Question
    30+ Posts Ramnight's Avatar
    Jan 2021
    Vicksburg, Michigan USA
    Default Champion IRS Shock Adjustment Question
    I have a 2012 wing with the IRS kit and tried to adjust the shocks for a higher ride, and I could not get the lower ring on the shocks with the holes to turn. I did not want to put to much torque on them and damage something. My question is, are all of the shocks on these kits adjustable, or maybe I need to get a larger spanner wrench?
    Thanks for the advice
    Quote Originally Posted by Ramnight View Post
    Use a lot of WD40....And take the weight off the shocks by jacking up the body...
    Jan 2021
    This worked great. After a night of WD-40 soaking on shock adjusters, one good pull broke them loose, then they turned easy. I spent more time removing the tires and puting them back on than adjusting the shocks. There are no good words on the close fit on these tires. Unless the previous owner put oversize tires on it.
    Thanks again
  1. Champion IRS Kit Question
    By Ramnight in forum Champion Trike
    Last Post: 09-12-2022, 04:01 PM
  2. Roadsmith irs vs Motor Trike irs
    By david1144 in forum Honda Trikes
    Last Post: 08-31-2015, 10:52 PM
  3. Question on adjusting shocks on Champion IRS kit
    By ColoNavy in forum Honda Trikes
    Last Post: 06-30-2015, 06:38 AM
  4. Champion Rear Shock Adjustment
    By scribe5 in forum Honda Trikes
    Last Post: 10-22-2013, 06:58 AM
  5. Front shock adjustment
    By ODDOMAN in forum Stallion Trikes
    Last Post: 03-05-2012, 05:21 PM
