Likes Likes:  4
Thanks Thanks:  1
Results 1 to 20 of 22
Thread: Brake puck
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    Default Brake puck
    I purchased a 22 piece brake caliper tool to Push the puck back into the caliper. It does not work on my rear calipers. Is there a special manufacturer that makes one that will work on these calipers?
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Oct 2018
    Ramseur NC USA
    I understand how to put the brakes go on. My concern is the caliper tool I have does not work with these calipers. It's an automotive caliper tool and these calipers appear to be too small for the unit to work. Unit does not fit inside the caliper. And All the discs that come with the tool do not fit the puck like they should.
    Jan 2009
    MA,
    Quote Originally Posted by TarheelLeo View Post
    Take two flat head screwdrivers cross them over and turn in the piston , my car brake set was to big , this works fine .
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Did you make sure that the emergency brake was loosen up, before pushing on the puck!
    Oct 2018
    Ramseur NC USA
    THE TOOL DOES NOT FIT INSIDE THE CALIPER. Got nothing to do with the emergency brake being on
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
    That tool is kinda of clumsy with smaller calipers. Have you tried using a needle nose pliars? I found the points work good on some smaller pistons. The caliper piston tool I have can be used with a 3/8 drive extension and ratchet. A lot of the cheaper kits have 2 holes machined into the piston plate, I do not like this set up. This is what all of my discs look like
    Oct 2018
    Ramseur NC USA
    Jack, do you happen to know the size of the disc that is used on these pucks? 19 Tri Glide. I have 18 discs in my kit and none of them fit the puck the way I think they should fit. None of them fit flush. Only two are even close and have the right size pins
    No I do not, I have not replaced these brakes yet. if you can measure the diameter of your piston I will check my set to see if I have the right adaptor
  11. #10
    Dale, my smallest adaptor is 1 1/2 inches, it is double sided having different spaced pins on either side, it has a 3/8 square drive center for use with a ratchet also
  12. #11
    Oct 2018
    Ramseur NC USA
    I have two inch and a quarter adapters that are the size of the puck but only one has pins that are real close to fitting. The adapter will fit on the puck but the pins don't line up exactly like they should. I'm not happy with the way it sits on the puck
  13. #12
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Excuse me for trying to help!
  14. #13
    300+ Posts
    DOKK's Avatar
    Dec 2020
    Manchester TN USA
    How about a small C-clamp? I've used them on many applications.
    2016 Tri Glide, More DK than HD. Just shut up and ride.
  15. #14
    Jan 2009
    MA,
    I did mine 2 weeks ago with two screw drivers why buy a $150. tool
  16. #15
    Jan 2009
    MA,
    Quote Originally Posted by DOKK View Post
    C clamp dont work you have to turn the piston in
  17. DKCustoms postbit
  18. #16
    Dec 2013
    Clarion PA USA
    I remember now made my own from 2 grade 8 bolts and a piece of strap metal not sure if I even kept it.
  19. #17
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Quote Originally Posted by nucseal View Post
    Darn Pat, guess ya don't need to offer next time. No problem,I will still ask ya.lolol & won't holler at ya.
  20. #18
    100+ Posts Koolbreeze's Avatar
    Oct 2018
    Stewartstown, PA, USA
    Default Just a FYI
    For others that may read this post:
    I bought one of those tool kits for use on my VW and thought I could use it on my Trike rear brakes, like you I found one close but the pins were just a little bit wide.
    I took a file and filed on the pins, making them a little smaller so they fit in the caliber puck holes - problem solved.
    Took me about 20 minutes as I wanted to keep them round and not get too small and break off in use.
    They appear to be pressed in so I expect if one breaks you could get a small diameter rod and replace them.
  21. #19
    Oct 2018
    Ramseur NC USA
    Somebody on here gave me the suggestion of using a pair of needle-nose pliers. It worked great.
  22. #20
    You are welcome I started doing it that way many years ago before I finally bought a complete kit from Mac Tools. It sure made my job easier and faster
    I also had a Snap On Tools Spanner wrench that worked on many calipers
  1. Bleeding the brake/clutch lines to replace the DOT 4 brake fluid.
    Last Post: 10-07-2018, 05:03 PM
  2. Replies: 2
    Last Post: 02-03-2017, 12:27 PM
  3. E-Z Brake Extended Brake Lever
    By Sunman in forum Harley Freewheeler / Road Glide 3
    Last Post: 01-21-2016, 05:28 PM
  4. To Brake or Not to Brake?
    By BELCHER in forum Tires, Wheels, Brakes, Front End
    Last Post: 08-14-2013, 04:28 PM
