Likes Likes:  6
Results 1 to 6 of 6
Thread: Rear Suspension Goldwing Champion
    Feb 2021
    Pleasanton
    Default Rear Suspension Goldwing Champion
    Howdy,
    I have a 2006 Goldwing Trike w/champion kit. I have had it for 10 years and suddenly I have lost all suspension on the rear. I have absolutely no rear suspension, any little dip or bump in the road and I am scraping the exhaust pipes, I can't go over any speed bumps without nearly high centering the trike.
    Is it possible I have a broken torsion bar?
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Doug, Welcome to Trike Talk from West Virginia.
    It sounds like a good inspection is needed. If it is a straight axle model, it should be easily spotted.
    If it does have IRS, a sway-bar could seize up and stop moving and allowing the suspension to be active.
    The sway bar can be diagnosed by disconnecting each end at the lower a-frames.
    Jim Murphy
    Iron Butt Rider 2001
    Doug........Welcome to Trike-Talk.............
    Martinsburg, WV
    Cool
    Jim Murphy
    Oct 2020
    Douglas,Arizona, USA
    Default rear suspension
    I dont believe champion uses torsion bar springs . they use 2 coil over shocks and one central shock, where the original GL shock went.. Take a look under there, to see whats going on.
    Im sure more knowledgeable folks will come along with other suggestions.
    Rick.
    Martinsburg, WV
    Cool
    Quote Originally Posted by Bigbikerrick View Post
    Rick.
    Rick, Welcome to Trike Talk from West Virginia.
    Glad you finally chimed in too.
    You describe the Champion straight axle for the GL1500 and the GL1800.
    Champion uses coil-overs for their suspensions, 3 on the GL1500 and 2 (axle mounted) on the GL1800 with a straight axle along with the OEM mounted coil-over..
    The IRS suspension also uses 2 coil-overs and a sway-bar and eliminates the OEM coil-over.
    Jim Murphy
  1. 2008 Honda Goldwing Champion Trike rear rims
    By Glenda McGinty in forum Champion Trike
    Last Post: 11-30-2019, 05:05 PM
  2. Replies: 0
    Last Post: 09-19-2019, 08:32 AM
  3. TriGlide Suspension Upgrade By Progressive Suspension
    By JohnC in forum Harley Tri Glide
    Last Post: 02-22-2012, 05:22 PM
  4. Which is best the Champion Independent Suspension or Solid Suspension.
    By glawrence7 in forum New Member Introductions
    Last Post: 11-24-2010, 12:00 AM
Tags for this Thread
