Likes Likes:  8
Results 1 to 9 of 9
Thread: Checking Engine Coolant
    60+ Posts Tony8's Avatar
    Nov 2017
    Avon,Ohio USA
    Default Checking Engine Coolant
    When checking the engine coolant do you turn the bike off or leave it running when pulling the coolant dip stick? I checked the coolant when it was cold and the coolant was between the 2 marks on the dip stick. Owners manual says to check after the trike gets to operating temperature, but it doesn't say if the bike should be running or not.
    Any help is greatly appreciated.
    Thank you.
    Tony
    When the engine is hot and you shut it down excess pressure/coolant bleeds off into the reserve/overflow tank. The service manual says "Check the coolant level of the reserve tank with the engine running at normal operating temperature."
    The dip stick level should be somewhere between the upper and lower marks. If you check it right after you shut off the hot engine and before it starts pulling coolant back into the cooling system that reading will be high so make sure you do it while the engine is running at normal operating temperature.
    Nov 2017
    Avon,Ohio USA
    Thank you very much for the information. So I'm correct in assuming that the reserve tank cap will not be under pressure?
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    You are correct T8.
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
    Nov 2017
    Avon,Ohio USA
    Thank you. A whole lot different than working on my truck. lol
    150+ Posts geraldlanc's Avatar
    austin tx usa
    Default Adding coolant
    So if the dipstick shows low, should coolant be added to the reserve tank?
    Gerald
    Nov 2017
    Avon,Ohio USA
    My service manual says "If the level is low, fill tank to the upper level hole with a 1:1 mixture of distilled water and anti-freeze".
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    Quote Originally Posted by Tony8 View Post
    What you can do is stop by a Honda car dealership and buy a gallon of the blue premix. It's identical to the Honda motorsports coolant but a little cheaper and there are way more Honda car dealers around anyway...
    Sep 2016
    Springfield, Mass. USA
    Quote Originally Posted by pwhoever View Post
    I thank you for this information:
    I always change my rad fluid every year, BUT it was getting quite exspensive at the m/c Honda's deal'rr................ I'll go buy a jug of blue pre mix this morning...@ a Honda car dealership, just three miles from my home instead of a twenty two one way mile trip....
  1. Newbie Question About Checking the Coolant
    By Tony8 in forum Honda Trikes
    Last Post: 03-01-2018, 03:56 PM
  2. The Coolant Goes In...The Coolant Goes Out
    By Jerry/MD in forum Harley Trike Conversions
    Last Post: 06-28-2014, 07:36 AM
  3. Checking coolant level in overflow bottle???
    By JaysGone in forum Honda Trikes
    Last Post: 09-03-2013, 10:43 PM
  4. checking coolant level
    By geraldlanc in forum Honda Trikes
    Last Post: 11-22-2011, 11:19 AM
  5. Engine Coolant Leak
    By Pooh105 in forum Stallion Trikes
    Last Post: 04-26-2011, 03:20 PM
