BigN693GorillaEnabled TrikersFull length floorboards
Results 1 to 3 of 3
Thread: Adjustable Pre load
    Jan 2021
    Merritt Island Florida
    Default Adjustable Pre load
    My 2016 Goldwing Trike has the adjustable pre load option just like the factory. After seeing a video of a standard non trike goldwing being adjusted, the rear end moves up and down while the preload is adjusted. I wanted to see if my trike movement was the same while using a marked stick. I went from 0 to 25 and back to 0 with no movement of the rear end. Can someone clarify if the preload on the trike is working properly? I’m suspecting the preload just compresses the springs on the trike and does not affect the ride height.
  2. Roadsmith banner
  3. #2
    80+ Posts Wingrider55's Avatar
    Oct 2015
    Kingston, Illinois
    Look for this video, it explain how the pre-load system works. Also on my trike, before I had the per-load rebuild in would not apply any pressure until it got to 12 on the system. After the rebuild in now work starting at 1. I sent mine to Traxion for the rebuild and they replaced the hose with a steel braid hose and rebuilt the pump.
    Roadsmith Pre-Load Adjustment System Video
    By Cut N Shoot Customs in forum Cut N Shoot Customs
  4. #3
    Jan 2021
    Quote Originally Posted by Wingrider55 View Post
    thank you, I just need to clarify if the rear trike body goes up and down with the pre load adjustment, or it’s a mechanical movement underneath independently and the body height does not reflect the adjustments.
  1. Roadsmith Pre-Load Adjustment System Video
    Last Post: 01-14-2024, 07:59 AM
  2. Goldwing 1800 Voyager Pre Load Figured Out
    By speedbuggy in forum Outrigger Style Trikes
    Last Post: 08-07-2017, 06:25 AM
  3. pre load
    By hd4bw in forum Outrigger Style Trikes
    Last Post: 11-06-2013, 07:07 PM
  4. pre-load with Roadsmith Kit
    By minnleeboy in forum Honda Trikes
    Last Post: 08-10-2011, 07:51 AM
  5. Shock pre load on CSC Trike
    By Mikethetrike in forum Honda Trikes
    Last Post: 11-22-2009, 01:33 PM
