Likes Likes:  8
Results 1 to 8 of 8
Thread: Any concerns with a 1995 Electra Glide Frankenstein conversion?
    1+ Posts TIME MACHINE's Avatar
    Mar 2021
    King George, VA
    Default Any concerns with a 1995 Electra Glide Frankenstein conversion?
    Hello everyone,
    Thanks for allowing me to be a part of the forum. I am thinking about purchasing a 1995 Electra Glide (FLHTP Police Bike) with 34k miles, for $4,000. The bike is carbureted, but I’m not too concerned with that.
    I see that the Frankenstein conversion (premium package) is about $8000, so I’d have about $12,000 in it when done.
    I saw someone here on the forum mention in an older post that the “gearing on older Harley’s is not ideal for a trike conversion”. Is this a serious issue? I don’t expect to be running on the freeways at 75+ mph, if that is the problem.
    I’m pretty sure that the absence of a reverse gear will be a minor annoyance, so that shouldn’t bother me too much.
    Any input, thoughts, or recommendations would be greatly appreciated before I pull the trigger. The only part of the premium kit that concerns me is the exhaust, not knowing what it sounds like. Thanks again!
    Aaron.........Welcome to Trike-Talk................
    welcome arron sounds like a good plan to me. you can always adjust the pulley size later if necessary
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Aaron, Welcome to Trike Talk from West Virginia.
    The EVO is known to be down on top end highway speed compared to the TC88 but you can still get more mid-range power and torque by simple cam change and exhaust choices. Of course mileage will suffer unless you bump up the compression. A gearing change will help on the flat but then puts a further load on the engine (run hot) and going the other way will run the engine at more RPM's.
    Look at cams/exhaust systems and upgrading the heads.
    Jim Murphy
    Iron Butt Rider 2001
    90+ Posts
    Oct 2018
    Linden, TX
    Champion conversion on my 98 ultra. Bone stock Evo motor. No problem running 80-90 if that's your style. I run 65 on hiway. Trike kit does lower mileage/extra weight. 1-up 35-40mpg . 2-up 30-34 mpg. Ken
    Evo engine bikes are a good platform
    Like Lee said they can benefit from cam and head work for the added weight of a trike kit
    You can also change your gearing via the tranny gears and sprocket changes
    Stay with us for more help and tech tips
    Dec 2013
    Clarion PA USA
    Default what Jack said
    Do it you will not regret it make it your own and one of a kind of sorts. I would love to do one myself. Possibly a 1200 sporty... Ride safe Fred
    Jan 2009
    MA,
    I would not do it , that bike stock is barely 50 horse power, you do motor work to it probally spend $2500 , then you will run in to other problems & extra's $$$ , by the time your done you will be $16000 &. then try to sell it it wont be worth $10000. The Frankenstein have no trunk or saddlebags I did a 2007 dyna with a frankenstein kit it was a blast to ride the owner got sick had to sell he got $8500. had close to $20000. in it . you look around you can find a 2009 - 2012 tri glide $15000. - $18000. same thing you find a 2015 -2016 freewheeler for that price, it will allways be worth $15000. If you get a Frankenstein get the upgraded on the brakes
  1. 2006 Harley Electra Glide, 2006 Motor Trike conversion
    By Wayne Heidelberg in forum Harley Trike Conversions
    Last Post: 04-22-2018, 04:58 PM
  2. Replies: 19
    Last Post: 01-08-2015, 05:34 PM
  3. Handling & Safety Concerns using Lift Kit on my Tri-Glide
    By PopDukes in forum Harley Tri Glide
    Last Post: 12-13-2013, 08:37 PM
  4. Need info on Trike conversion kit HD Electra glide
    By Mustang7777 in forum New Member Introductions
    Last Post: 06-08-2013, 12:51 PM
