LD-Ordie4rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie4SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  1
Results 1 to 3 of 3
Thread: Champion Variable sway bar question?
    20+ Posts
    Jun 2016
    San Luis Obispo, CA, USA
    Default Champion Variable sway bar question?
    I purchased a used Goldwing trike with Champion conversion that is equipped with the variable sway bar option. The prior owner who had the conversion done could not explain it to me. The problem is that I do not have any information that explains how this option works. There is nothing on the Champion Trikes of Arizona web site. I have a switch on the dash that adjusts the plunger in and out. What changes with the adjustment?
    Any help would be appreciated.
    Dave
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Quote Originally Posted by Slvrvalk1 View Post
    Dave
    The left side of the sway bar has a direct non-flexible link attaching to the lower control arm.
    The right side has a torsional bar that rotates allowing for flexing when fully extended by the electric motor.
    Check to see if the motor is working and rotating the end 90 degrees.
    Retracted, the sway bar is operating at its stiffest setting.
    GL1800 Champion Variable Swaybar.pdf
    Jim Murphy
    Iron Butt Rider 2001
    750+ Posts
    Jan 2010
    east windsor ct
    oops
  1. Roadsmith Performance Sway Bar
    By kerr88 in forum Honda Trikes
    Last Post: 12-28-2016, 04:21 PM
  2. Heavy Duty Sway Bar for Roadsmith Trikes
    By Greg Christian in forum Honda Trikes
    Last Post: 12-07-2016, 04:36 PM
  3. Sway bar for trike??
    By namsgt1946 in forum General Discussion
    Last Post: 07-20-2011, 11:13 PM
  4. Variable pressure clutch
    By Redrider in forum Harley Trike Conversions
    Last Post: 06-25-2010, 01:38 PM
