Likes Likes:  4
Results 1 to 3 of 3
Thread: Question about rear shocks with Variable Sway Bar Control Optionn
    20+ Posts
    Jun 2016
    San Luis Obispo, CA, USA
    Default Question about rear shocks with Variable Sway Bar Control Optionn
    My conversion (Goldwing) was done in 2009 with IRS and the variable sway bar option. I took off a rear tire today and did not see any way to adjust the shocks. Does the variable sway bar take the place of adjustable shocks?
    Thanks.
    Dave
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Dave,
    The rear shocks are only adjustable by tightening the spring tension. Increasing the spring tension will raise the trike up and you need to be careful to make this adjustment evenly on both side. Raising the trike with this suspension will alter the rear wheel camber and change or cause tire wear.
    Jim Murphy
    Iron Butt Rider 2001
    20+ Posts
    Jun 2016
    Lee -
    Thanks. The holes in the bottom sleeves were filled with grime so I didn't see them. My bad.
    Dave
  1. Champion Variable sway bar question?
    By Slvrvalk1 in forum Champion Trike
    Last Post: 03-20-2021, 10:21 AM
  2. Roadsmith Performance Sway Bar
    By kerr88 in forum Honda Trikes
    Last Post: 12-28-2016, 04:21 PM
  3. Heavy Duty Sway Bar for Roadsmith Trikes
    By Greg Christian in forum Honda Trikes
    Last Post: 12-07-2016, 04:36 PM
  4. Sway bar for trike??
    By namsgt1946 in forum General Discussion
    Last Post: 07-20-2011, 11:13 PM
