Likes Likes:  6
Thanks Thanks:  2
Results 1 to 12 of 12
Thread: Power Vision Question
    40+ Posts
    May 2016
    West Coast BC Canada
    Default Power Vision Question
    I have my Power Vision gauge function set to indicate Engine Temperature and Head Temperature - I find the two temperatures [after warming up] only differ by a couple of degrees or read almost the same on my 2018 Tri Glide - is this normal on the M8 engine? I expected the Head Temperature would be somewhat higher than the Engine Temperature. Example -my 40 min. ride today at 50 degrees ambient, both temperatures were within 2 degrees of each other. [I have the Dakota Gauges which shows Head Temperature but I really think it is Engine Temperature as it follows the PV Engine Temperature read out from cold to operating temperature, not the derived Head Temperature].
    Ron
    Dec 2012
    Santee
    I was looking at my temps today and the head temp was running about 10 degrees hotter than engine temp.
    Ray
    2017 Harley Triglide
    Tijuana Border
    40+ Posts
    May 2016
    Quote Originally Posted by Rmitchell55 View Post
    Yes - thats what I would expect something in the range of 10 to 20 degrees, depending on conditions. Somehow I am getting the engine temperature measured on both selected gauge functions. I have tried removing the head temp. and the engine temp and then reselecting - same result. I think I will contact Dyno Jet.
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    The Power Vision temp gauges are a bit confusing.
    The ET is a direct readout of the temp of your sensor on your rear cylinder head.
    The CHT is an algorithm derived number and it does vary from the ET some. Next time you're out, give it some serious throttle for 5 seconds or more, you will see the CHT drop some and the ET stay about the same.
    That is because one of the factors that the CHT uses to display a number is the intake air temperature, which will drop when you are pulling larger quantities of air thru the intake manifold.
    ET is used by the ECM for most of the lookup tables including the fuel tables and multipliers, while CHT is used primarily for spark temp correction.
    I use my PV to monitor the engine vitals while riding and I do not use the CHT read out, I prefer to know that actual temperature of the rear cylinder head on the M8's. (On the Twin Cams it is a readout of the rear of the Front cylinder, which is why the ET generally reads cooler on a Twin Cam than an M8, since it is getting more wind)
    www.DKCustom.com
    40+ Posts
    May 2016
    Thanks Kevin - will just stick with ET. [Will give your 'serious throttle' a go, next ride - hopefully tomorrow, as it may be above 40F.]
    Ron
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    My plan is to add a cam and air cleaner to my 20 TG. With that in mind is the Power Vision the "Go To" tuner and if so is there a certain model that is considered the best. I'm going to loose my warranty due to other changes I'm making so I figured screw it I might as well do the engine upgrades also.
    Quote Originally Posted by molokaimike View Post
    You will want the PV2 for can bus Harley application, get with Kevin
    @ D K Customs for more info and better pricing Phone: 662.252.8828Text: 662.420.4891
    I am spoiled and think the PV is the best tuner out there @ this time
    200+ Posts Wmitz's Avatar
    Jun 2018
    Crossville, TN, USA
    I got my new license for my PV hooked it up, dropped in a stock improved tune, runs better, seems to have the same mileage, got a little over 250 miles on since. With the stock bars I couldn’t get it to mount the way I wanted, so I went with an Arkon mount, mc25mm17 system. Comes with a 17mm ball for the PV mount. Name:  785A950D-90B8-4C1E-B4C1-1DBC410F1A33.jpeg
Size:  775.4 KBName:  0E6DD38F-F3E4-48F8-BDFE-7B7F92E4B1D0.jpeg
    100+ Posts
    Highaltidude's Avatar
    Sep 2019
    Somerset, KY, USA
    Quote Originally Posted by ron49th View Post
    Ron
    I've had the Power Vision on my bike for two months (2019 Tri-Glide).....
    I can't find a choice for Head Temperature.
    I have Engine Temperature and Coolant Temperature, and display both.
    There is normally around a 100 degrees difference between them.
    Anyone know why I don't have a Head Temp choice?
    Do you guys also have the Coolant Temp choice???
    Chucktryingtolearn
  11. #10
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Highaltidude View Post
    Chucktryingtolearn
    They don't call it Head Temperature. The ET is a direct read of the heat sensor in the rear cylinder head.
    There is also a read out call CHT...which you would think would stand for Cylinder Head Temperature, BUT, that is the algorithm derived number I mentioned up above.
    Yes, I have the Coolant Temp choice and run it sometimes. It varies a lot for me. On the interstate I'll see it floating around 160+-, but if I get slowed down it will climb pretty quickly, and, at or near, a stop it will get up to 190 pretty quickly.
    www.DKCustom.com
  12. #11
    40+ Posts
    May 2016
    Chucktryingtolearn
    Go to the screen - Assign Signal on the screen you will see BASIC SIGNAL - right beside it will say CHANGE - hit CHANGE and ADVANCED SIGNAL will be available.
    Ron
  13. #12
    100+ Posts
    Sep 2019
    Somerset, KY, USA
    Ron
    That's where it was!
    Thank you!!!!
    Chuck
  1. Power Vision Auto Tune question
    By jwkhd1 in forum Harley Trike Conversions
    Last Post: 08-23-2015, 10:28 PM
  2. Power Vision and Warranty question
    By Scorpio49 in forum Harley Trike Conversions
    Last Post: 04-19-2014, 07:59 AM
  3. Question about Power vision
    By Minnesota Dick in forum Harley Trike Conversions
    Last Post: 09-05-2012, 07:23 PM
  4. Power...Power, I need more power
    By SJR in forum Harley Trike Conversions
    Last Post: 08-14-2011, 10:37 AM
