LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  9
Thanks Thanks:  3
Results 1 to 19 of 19
Thread: 2015 tri glide
    30+ Posts
    Dec 2020
    Seabrook, SC, USA
    Default 2015 tri glide
    New to me tri glide. 8400 miles, previous owner had reverse motor issues, at 1K miles, reverse motor replaced, at 6K miles, had reverse motor repaired. now I have it, put on 3K more miles. Reverse motor fell out and dangling by the cables. Should this be on my dime? Your opinions please.
    Thank You.
    That is a real tough question
    IMO, I cannot see any reason the mounting bolts holding the motor could both fall out with out it making some noises prior. Who ever did the last install did not check the mating surfaces before reinstalling it or did not torque the bolts ?
    Quote Originally Posted by Fasteddy View Post
    Thank You.
    Who did the replacement.....??...If it was the previous owner lots of luck...If it was a Harley dealer and it was replaced by them with a Harley motor and you have the receipts you might have a chance....??...
    agree with above but also i suggest maybe time to put a mechanical reverse in. i put one on my 13 and really like it.
    30+ Posts
    Dec 2020
    Seabrook, SC, USA
    Installed by HD. They have all the records.
    Then you might come out OK........Please let us know what the final outcome is....
    30+ Posts
    Dec 2020
    Seabrook, SC, USA
    Thumbs up 2015 Tri Glide
    Thank You.
    Problem solved. Savannah HD will replace at no cost to me.
    70+ Posts Tomswede's Avatar
    Jul 2018
    Lugoff, SC, USA
    Reading about all the issues with the original reverse, well mine is now also out of commission, no life , checked fuse, the " R" illuminates but no action when I push it to reverse, so since it seem to be the concenses that a mechanical version is the better way to go, where do I find one? Part number ? Are there options ? Thanks
    Quote Originally Posted by Tomswede View Post
    just search harley davidson reverse. champion, motor trike and a couple others make them. But most important contact Randy at "Cut-N-Shoot see ad below. he will hook you up at the best price.
  11. #10
    Jul 2018
    Lugoff, SC, USA
    ok, thank you, will do
  12. #11
    Jul 2018
    Lugoff, SC, USA
    Default Update on reverse issue
    So today was reverse motor day, as I was reading some postings about this very common problem, I decided to try a suggested remidy, putting the trike in reverse and holding in the "R" button I gave a few quick throttle twists, and low and behold, the reverse started to work as normal again.
    the post I read said that the brushes inside the reverse motor has a tendency to bind up, so the engine vibration loosens them up to give them contact, not a fix, but as infrequently as I use the reverse it will work for me, and atleast I know where the problem is.
  13. #12
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    That's a new one for me Tom, glad it worked out for now.
  14. #13
    Quote Originally Posted by USAZR1 View Post
    Something else I've seen people do, is give the reverse motor a good whack with a rubber mallet. Your idea might be the better one though, as crawling under a trike can be rough for us old farts.
    If you ever take one apart you’ll see that the carbon brushes tend to corrode and fall apart so to fix by hitting The motor is just temporary And will stop working at the most In opportune time I changed my brushes three times before I finally went mechanical..
  15. #14
    When you first press the R button the ECM is supposed to force a bit higher RPM for the reverse motor to operate without being a drag on the battery
  16. #15
    correct me if I’m wrong🤔..
    I think that’s only on the 2017 and up..My 2011 didn’t do it but my 2017 did and my 2019 does...
  17. DKCustoms postbit
  18. #16
    My 15 Freewheeler did
  19. #17
    I stand corrected...👍
  20. #18
    Bob, I dunno when HD wrote the ECM idle up program for The Trikes
    One thing to keep in mind, the first years 08-12 were built by Lehman in Spearfish SD
    I dunno what those ECM programs were capable of?
  21. #19
    Slight correction Jack. The first TRI-Glide was introduced in July of 2008 as a 2009 Model. Beginning with the 2011 model year production, the Tri-Glide is produced in York PA Just to clarify.
  1. 2015 Tri Glide money pit
    By joelin5386 in forum Harley Tri Glide
    Last Post: 03-12-2016, 09:43 AM
  2. My 2015 tri-glide mysterious red
    By trikedog007 in forum New Member Introductions
    Last Post: 06-22-2015, 09:20 AM
  3. Heated Hand Grips- 2015 Tri Glide
    By Tadgh45 in forum Harley Tri Glide
    Last Post: 03-06-2015, 12:30 AM
  4. CB on 2015 Tri-Glide- is it worth it?
    Last Post: 02-25-2015, 09:20 AM
  5. Good and bad of the 2014 & 2015 tri glide
    By moonmullins in forum Harley Tri Glide
    Last Post: 12-25-2014, 04:43 PM
