Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Results 1 to 10 of 10
Thread: Gear It Down
    Apr 2018
    bay city,mi usa
    Default Gear It Down
    I would like to lower the the drive ratio so I don't have to slip the clutch so much when I take off. I have 2010 Harley road king with a Road Smith conversion. I would like to go down about two teeth some where, trans pulley or motor compensators sprocket What is the best way?
    larry things to consider is what other costs besides the sprocket. if you change the compensator sprocket do you need to change the chain besides. if you change the trans sprocket will the belt or chain allow to adjust out the slack. i did the trans on my 07 road king/champion and was pleased. the belt took up the slack. good luck
    Apr 2018
    bay city,mi usa
    I wanted to change the trans pulley to a smaller one(two teeth smaller) but was told by the installer there wasn't enough adjustment to tighten up the belt. That why thought of changing the compensator sprocket.
    what is your current sprocket tooth count both front and rear. mine was 32 front 79 rear switched to 30 front same rear
    again it was a 2007 RK with a Champion straight axle conversion. belt did tighten up.
    Dec 2013
    Clarion PA USA
    Just a thought what size tires are you running on the Back I switched from 205X65Rx15 TO 205X70RX15 to lower rpms in gearing. You may want to go the other way. From a higher tire to a lower one 60series to 50 series for example just sayin trying to help... if it didn't affect ground clearance. Fred
    Apr 2018
    bay city,mi usa
    Default Gear it Down
    I want to go to go down to a 30 tooth from a 32. I have a call into Road Smith about if there is adjustment to tighten the drive belt. If not looks like the compensator sprocket is the way I'am going.
    Apr 2018
    bay city,mi usa
    After talking to Road Smith, looks like the compensator sprocket is the way I am going. Not enough adjustment to go to a smaller sprocket . Also looking into smaller rear tires as suggested.
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by zrturbo View Post
    now I can't speak about Road Smith but I went from a 32 to a 30 on my 09' Triglide without swapping drive belts. Good luck Fred
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Smaller rear tires will compromise ground clearance.
    Jim Murphy
    Iron Butt Rider 2001
  11. #10
    Dec 2016
    Wamego, KS, USA
    Default Belt change
    With a shorter (less teeth) belt you can probably change the front sprocket without any trouble at all and get your adjustment you need. There's a wide range of tooth count belts for Harleys out there, and if Harley doesn't make one, there's probably one for the Buell side of things that would meet your needs. Hell, even some years and models of Victory had belts of the same pitch that will work on a Harley just fine. Just a thought, but looking at the date, you've probably handled it your way, by now.
  1. Down Shifting for a slow-down
    By mgwtrike in forum Honda Trikes
    Last Post: 03-06-2016, 07:11 PM
  2. starter gear teeth 12v 1600 vw of the gear
    By bluedog in forum VW Powered Trikes
    Last Post: 07-24-2013, 04:22 PM
  3. Down South Trikin
    By Trikerjim in forum New Member Introductions
    Last Post: 02-16-2008, 01:21 PM
