Likes Likes:  28
Results 1 to 20 of 20
Thread: Question about rear tire on front reverse mounted....
    150+ Posts
    Apr 2018
    Cordes Lakes, AZ
    Default Question about rear tire on front reverse mounted....
    A new front is starting to sneak up on me, and I have a question about putting a rear on the front mounted backwards.
    I understand that a rear could have a larger contact patch and deeper treads equaling more traction and longer wear, but what is the logic to mounting it so it turns backwards?
    TIA for the information
    Lon
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by Teufelhunde View Post
    Lon
    It is the way the tire casing is spliced rear tires are constructed to hold the splice on acceleration. Front tires spliced to hold tight on deceleration, so back on front reverse so spliced is not stressed under braking easy peasey
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    Quote Originally Posted by Fearless View Post
    Fearless is correct. The center carcass is joined together with an angled bevel type joint. This joint is orientated so that as the tire rotates, the joint stays shut. As the rear tire provides drive and the front tire provides braking, the joint is made one way for the rear tire and the opposite way for the front.
    I use a Dunlop Rear Tire with Reverse Rotation on the front. I am very pleased with it. I keep the air at 40lb.
    Jun 2010
    Indianapolis, In.
    Why not use the Avon Trike tire???
    Sorry but, 40psi = harsh ride!! I run 36psi, much smoother ride!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Dec 2013
    Clarion PA USA
    You certainly can your choice however it seems several people have had repeated issues with them i.e. vibration etc. For the investment and time I prefer to stay with what I have experience with, the Michelin Commander II rear tire on front works beautifully for my needs. Handling dry or wet roads, braking, and not to mention wear. Why go else where for what might me a good tire. Good luck on your choice ride safe Fred
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    I fully understand the reason for installing the rear tire backwards on the front, but what about the tread pattern? Wouldn't that contradict the rain dispersing design?
    IBA#61162
    PATRIOT GUARD
    USMC
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    I’m no tire engineer but in looking at different tread patterns I cannot see the logic. Avon is the most strange IMO. I think it’s a matter of preference and opinion on the part of the designers/engineers.
    I recall Harley’s fiasco when they introduced the D407 tire several years ago. Lots of problems with cupping so they reversed the tread pattern and called it a D408. I think I’m correct about this but if my memory if faulty I’m sure someone will speak up.
    From all the good reports I’m not all that concerned. I think worn tires with little tread depth are a bigger concern.
    Dec 2013
    Clarion PA USA
    Gary
    I have ridden in driving rain with no problem, now r emember i slowed down considerably but still tracked really well. Even the occasional standing water there were no issues. For us anyway. Ride safe Fred
    350+ Posts
    RickDeVon's Avatar
    Jun 2010
    Pine Mountain,Ga
    Guys I need to know if this is like being on the "Dark Side" only backwards...lol
    Miss Mysterious...
    2015 Mysterious Red Tri Glide...
    Vance&Hines head pipe w/Rhinehart slipons...Slipstream Collection...DK Lift...11" Clearview w/ recurve...HD chrome Enforcers w/Goodyear Triple Tread Assurance...just a touch of chrome & LEDs...
  11. #10
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by RickDeVon View Post
    Yep... I was skeptical at first reading about Rear Tire on front until... I ran across an older friend and rider many years older than me if you can imagine that. He's in his Ninety's he his words are your crazy if you don't we did it for years.
  12. #11
    30+ Posts
    Sep 2016
    Tam[a Florida
    Default rear on front
    A. “older” shop owner told me that the race community has ran rear tires on the front for many, many years. Softer compound, deeper tread, and better wear during race environments. Just makes sense to Me!
  13. #12
    30+ Posts
    Sep 2020
    Sullivan,Ohio USA
    Teufelhunde.... Check out DK Customs. Kevin put up a video explaining the reasons you ask...
  14. #13
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    That is what I thought at first...until I looked at every other matched front and rear tire on two wheelers and stock on the Trikes too.
    This video shows it, then you can take a look at some bikes and see the same.
    www.DKCustom.com
  15. #14
    100+ Posts
    Feb 2017
    DE
    everyone, is busting my chops about mine being backwards... now i know it's on right
  16. #15
    50+ Posts nokkon wud's Avatar
    Feb 2021
    Clearwater, Fl
    I just put a rear on the front reversed. Between that and the MONO shocks I put in the trike rides great!
    The first 65 years of childhood is the hardest.
  17. DKCustoms postbit
  18. #16
    40+ Posts
    Feb 2021
    El Paso, TX USA
    Quote Originally Posted by hdwindjammer2014 View Post
    Gotta admit that I was pretty confused on the subject until I watched that video. Now it all makes sense.
  19. #17
    Quote Originally Posted by TwistedKarma View Post
    Don't listen to them, They're all jealous......Or lack imagination.....
  20. #18
    200+ Posts rayg5102's Avatar
    Nov 2012
    New Market MD
    Lon
    I had a Harley mechanic talk me into doing this on my 2019 after the front tire ran thin and kind on warped on me. I was skeptical, but did it on his advise. Best move I ever did. Ride was so much better both is ride and handling. I say go for it.
  21. #19
    450+ Posts TonkaDriver's Avatar
    Feb 2018
    Bagdad, AZ, USA
    I have over 18,000 on my Michelin Commander II and still going strong. Blue Collar Customs in Prescott Valley ordered and mounted mine. Look them up.
    Kurt
  22. #20
    150+ Posts
    Apr 2018
    Cordes Lakes, AZ
    Quote Originally Posted by TonkaDriver View Post
    Kurt
    Thanks for the shop info....
    Lon
  1. Replies: 1
    Last Post: 11-18-2015, 08:12 PM
  2. tire size for rear tire on front? 2007 goldwing trike
  3. New bt45 mounted in reverse direction
    By Chazzman in forum Honda Trikes
    Last Post: 08-18-2014, 03:28 PM
  4. Rear tire coming apart mounted in front. (Read 1st post)
    By Big_Steve in forum Tires, Wheels, Brakes, Front End
    Last Post: 03-16-2014, 11:17 AM
  5. Back tire up front and mounted reverse
    By Duck in forum Honda Trikes
    Last Post: 03-29-2013, 09:13 PM
