Likes Likes:  22
Thanks Thanks:  4
Page 2 of 2 FirstFirst 1 2
Results 21 to 27 of 27
Thread: Strange rear brake problem is Solved on 2018 GW CSC DCT
  1. #21
    Sep 2021
    Alberta
    Default mushy brake pedal
    I had a mushy brake pedal on my 07 street glide trike. I got a new distribution block build (up behind the battery ) and I used the fitting Harley has on the front calliper(noticed it on my buddies 09)that has a banjo fitting and a bleeder fitting as one piece. I also replaced the cartridge in the pedal. Blead the system down and now I have a solid pedal. Its still winter up here so I haven't ridden it yet but I know the the pedal is way different than before. This Harley doesn't have ABS brakes by the way.
  2. #22
    90+ Posts Sandman1's Avatar
    Jan 2021
    Palm Harbor, Florida, USA
    Cool
    Yes, this fix does work for the issue described by CSC, and that is the grease issue.
    One thing to note is that the ABS brake system on these new '18 & newer Honda Goldwings, is that this brake system is designed to utilize BOTH the front and rear brake working in unison at the same time, so do not expect to get optimal braking when using just the rear brakes alone, because you will not get sufficient braking when using just the rear brakes. You MUST use both the front and rear brakes simultaneously.
    I can attest that the brakes work fantastic particularly if you need to really brake hard-as Papa Zook mentions you MUST use BOTH FRONT & REAR BRAKES. The 2018 GW DCT Tour prior to the CSC conversion would have no issues on stopping when you clamped down on the front brake w/out using the rear brake pedal. But with the added weight of the trike kit if Ya really need to make a sudden Stop use BOTH front & rear brakes.
  3. #23
    Sep 2021
    Alberta
    Post Brake
    Quote Originally Posted by Sandman1 View Post
    As a rule I would say I use my front brake pressure more than my back brakes but I do use them both to stop even when the is not an emergency.
  4. #24
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Aren't the brakes linked so that the bike/trike tries to determine what is best needed to stop.
    What is a linked braking system on a motorcycle? A system that engages both brakes when either lever is applied. A technique in which the rider uses both brakes at once.
  5. #25
    Quote Originally Posted by cycle7447 View Post
    You have asked a very loaded question and one that has lore than one correct answer depending on the Bike/ Trike manufacturer
    Linked brakes are just what the name implies. The brakes on both axles are linked hydraulically be it diagonally or in most cases the front calipers are linked to the rear brakes when multiple piston calipers on the front axle have ( typically) center pistons applying pressure to front brakes via rear braking until you grab a handful of the front brake lever also to fully activate the front brakes
    The braking has nothing to do with the bike/ trike knowing what is best EXCEPT when you throw anti lock and traction control into the mix
    Now you have a computer and specific hydraulic valving involved along with wheel speed sensors very similar to how ABS works on your family car
    I hope this answers your questions
    Keep in mind all manufacturers use their own ( made for them) set ups
  6. #26
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    All of this helps - thanks.
    My bike has ABS and, also traction control. When I talked to my trike builder, he said that all of those functions will continue to exist when the unit is triked.
    The Harley Tri-Glide, for example has ABS and traction control - so, I have to imagine that when I trike my Harley, since it is already there, those functions will be working just fine. I do know that when I was ordering the trike kit, it sated that if my bike currently have ABS, I have to get the trike ABS package ($300 cost)
  7. #27
    Sep 2021
    Alberta
    Default brakes
    I don't have linked brake option on my Trike. Rider brain link only! lol
  1. CSC Encore 2018 Honda Goldwing DCT
    By Cut N Shoot Customs in forum Cut N Shoot Customs
    Last Post: 02-22-2021, 12:55 PM
  2. Carrying Extra Fuel When Traveling---Problem Solved (for me)
    Last Post: 07-26-2020, 06:25 PM
  3. problem solved
    By johndeeredr in forum Harley Tri Glide
    Last Post: 06-15-2016, 05:17 AM
  4. Could it be Coil Death? - Problem Solved!
    By CaveManDave in forum VW Powered Trikes
    Last Post: 05-01-2016, 10:20 AM
  5. Problem Solved
    By Trikenewby in forum Harley Tri Glide
    Last Post: 03-21-2016, 10:04 PM
