Likes Likes:  22
Thanks Thanks:  4
Results 1 to 20 of 27
Thread: Strange rear brake problem is Solved on 2018 GW CSC DCT
    300+ Posts paid4c4's Avatar
    Mar 2016
    Crestview Hills, KY, USA
    Default Strange rear brake problem is Solved on 2018 GW CSC DCT
    My rear brake pedal was mush and had to be pumped several times for the pedal to get hard and effectively operate the brakes. This most certainly sounded like a typical need to bleed the brakes to expel air from the system.
    I took my GW to my independent mechanic who was a Honda Red Tech for years before opening his own garage. He agreed that a good bleeding was needed. He bleed the brakes and bleed the brakes and the pedal got no better. A thorough brake system inspection revealed no leaks or other problems.
    I placed a call to Will at CSC to discuss my problem. Will was very helpful and as soon as I described the problem he said "stop go no further." I thought OK he sounds really sure he knows the fix to my problem. Will then explained that CSC had a number of brake calipers which were assembled with old grease. When left unused it causes the pistons to become stuck or sticky in the caliper bores. He said to remove the pads from the calipers and pump the brake pedal until the pistons traveled out of their bores and touched the rotors. I passed this on to my tech and we both had a good chuckle.
    About an hour later I got a text from my tech who said "I've learned something today!" The strange fix Will passed along worked and worked well. Bottom line I now have great rears brakes. I must confess that Randy aka Papa Zook told me so! Please don't tell him I admitted he was right and I was less right. I thought this might someone else with a similar brake issue.
    Bill
    Oct 2015
    Tampa
    Default CSC Sport (GL1500) no rear brakes
    I'm wondering if I have the same problem. My bike sat for about 6 months unmoved until recently. When I finally got it out I had no rear brakes and basically no rear brake pedal. I don't see any leaks under the bike where the brake fluid might of leaked out; however, it was low. I'll check this out. Thanks!
    40+ Posts Wing'n It's Avatar
    Sep 2019
    Eaton, Ohio, USA
    Mine has been back to the dealer two times for a mushy brake pedal. At one point we even took the rear calipers off put a block of wood in the pads and bleed them with the bleeders pointing up. No better but got a lot of "orange stuff" out of both sides?? Brakes are still not optimal but seem to be working so I'm riding it. Will try this and see if it's a solution,... thanks for the post.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Quote Originally Posted by paid4c4 View Post
    Bill
    I had the same problem, did the same thing you did. Same issue as you. Called Will, gave me the same advice as he gave you about the pistons. But, I did the same thing and nothing got better. I'm stuck.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    For those having this issue, I suggest that you do this test. With your trike turned off and the park brake off and sitting on a level surface, give your trike a gentle push and see if it rolls freely. If it doesn't that is a sign that the rear brake calipers may be sticking and need the above fix performed.
    Quote Originally Posted by FRR View Post
    Hydraulic brake systems have never played good with foreign materials ( too much assembly lube, moisture, wrong type of brake fluid) ETC
    This is why regular maintenance and up to date info like Randy has given here is a MUST read for everyone
    I always tell my customers, it does not so much matter how your bike runs, it better stop good and every time or very bad JU JU comes your way JMHO
    300+ Posts dadztoy's Avatar
    Dec 2011
    Georgetown, Tennessee, USA
    Read this post with great interest as I also have a mushy rear brake pedal on my CSC trike. I asked Will about it when my trike was back at the factory for other issues, but he said it felt pretty good. Still feels mushy to me though although the trike stops well enough.
    Question: If one pushes the pistons all the way out, does that not result in brake fluid all over the caliper or am I missing something? I have never rebuilt a caliper, so I am clueless to what happens when the pistons are popped out,
    but it seems to me like this would purge the system, at least that caliper, of brake fluid.
    dadztoy
    Quote Originally Posted by dadztoy View Post
    dadztoy
    If you do it on the bike be prepared to have fluid come out as the piston/ pistons come out
    If you remove the caliper from the bike you can let most of the fluid drain out of the hose mount, then use compressed air to pop the pistons out, be careful and wear eye protection
    Dec 2011
    Thank you Jack, that's what I thought would happen... Guess I'll try a bleed first...
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Tried this.. No difference and about never got the pistons back in
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    With this procedure, which CSC researched and developed to solve the soft brake issue, you do not remove the brake lines, bleed the brakes before or after the procedure or do any anything that causes any loss of brake fluid. You are simply removing the brake pads, pumping the rear brake pedal until the pistons are fully extended against the rotors, then compressing the 4 brake caliper pistons until they are fully 100% retracted, then reinstalling the pads.
    I have done this on two Goldwing DCT Encore trikes I built and it cured the soft brakes on both. The pistons will resist being fully retracted and make you think they will not seat, but they will. I used a large flat blade screwdriver to pry them into fully retracted position.
    With this procedure which CSC developed to some the soft brake issue, you do not remove the brake lines, bleed the brakes before or after the procedure or do any anything that causes any loss of brake fluid. You are simply dismounting the caliper, removing the brake pads, compressing the 4 brake caliper pistons until they are fully 100% retracted, then reinstalling the pads and remounting the calipers.
    Very good info, I clean the pistons as good as possible before pushing them in so as not to let any debris follow them in
    It can be a tedious chore on some calipers, but if done will help improve braking also
    If you are careful you can roll down the protective outer piston dust shield exposing the piston, you can then clean debris before pushing pistons in
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Yes, giving them a wipe down is a good idea, but these are mounted up top directly above the disc and in such a way that you will likely find little if any debris on the pistons. They are enclosed within the rear trike body fender well and are pretty well protected from the elements.
    250+ Posts
    56Elwood's Avatar
    Jul 2010
    Groveland Massachusetts USA
    With this procedure, which CSC researched and developed to solve the soft brake issue, you do not remove the brake lines, bleed the brakes before or after the procedure or do any anything that causes any loss of brake fluid. You are simply dismounting the caliper, removing the brake pads, compressing the 4 brake caliper pistons until they are fully 100% retracted, then reinstalling the pads and remounting the calipers.
    Really? That's it? I gotta get this done, hopefully they can fix the DCT shifting issue at the same time.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Good idea.. I tried it but the brake pedal still needs to be pumped. Any other suggestions?
    250+ Posts
    56Elwood's Avatar
    Jul 2010
    Quote Originally Posted by 56Elwood View Post
    OK, just back from the dealer after having the rear brake issue and shifting problems addressed. The tech did the procedure as outlined above and now the rear brake pedal is firm with great feedback and working as it should.
    He also installed the new module supplied by CSC and the trike shifts like a champ in all modes, whether shifting manually or letting the trans shift itself. Outstanding! Great job by Nault's, always take great care of me. Thanks also to Zook for all the great info
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Yes, this fix does work for the issue described by CSC, and that is the grease issue.
    One thing to note is that the ABS brake system on these new '18 & newer Honda Goldwings, is that this brake system is designed to utilize BOTH the front and rear brake working in unison at the same time, so do not expect to get optimal braking when using just the rear brakes alone, because you will not get sufficient braking when using just the rear brakes. You MUST use both the front and rear brakes simultaneously.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Did your dealer re-initialize the transmission after he installed the CSC shift module? This also makes for a BIG change in the way it shifts.
  19. #19
    250+ Posts
    56Elwood's Avatar
    Jul 2010
    Did your dealer re-initialize the bike after he installed the CSC shift module?
    Not sure, it was 41 degrees on the way home, seemed to shift a little "crisp" but I was leaning on it pretty hard so I really couldn't say for sure. It was not stated on the repair order that he did but I know he has done it before and so have I. Next time I ride it and get it sufficiently warmed up I will initialize it, that always makes a nice difference in how the bike shifts. Seems like need to do this every 2K to 3K miles or so.
  20. #20
    250+ Posts
    56Elwood's Avatar
    Jul 2010
    OK, rode the trike to work this morning (23 degrees when I left the house). Stopped for gas after about 20 miles and 3 bars on the temp gauge. Initialized the trans and rode to work with the DCT as smooth as silk. Looking forward to a nice (hopefully warmer)ride home later.
  1. CSC Encore 2018 Honda Goldwing DCT
    By Cut N Shoot Customs in forum Cut N Shoot Customs
    Last Post: 02-22-2021, 12:55 PM
  2. Carrying Extra Fuel When Traveling---Problem Solved (for me)
    Last Post: 07-26-2020, 06:25 PM
  3. problem solved
    By johndeeredr in forum Harley Tri Glide
    Last Post: 06-15-2016, 05:17 AM
  4. Could it be Coil Death? - Problem Solved!
    By CaveManDave in forum VW Powered Trikes
    Last Post: 05-01-2016, 10:20 AM
  5. Problem Solved
    By Trikenewby in forum Harley Tri Glide
    Last Post: 03-21-2016, 10:04 PM
