LD-Ordie4rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie4SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  2
Results 1 to 7 of 7
Thread: Rear End
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Default Rear End
    I have a leaking rear differential. It is definitely coming out of the rear cover and it may be coming out of the front seal also. It's a mess so I can't tell about the front seal. It is also all over the radiator. It shows only a couple of drops on the floor, but what a mess underneath. I know it's a Ford, but I can't remember if it's a 6.5" or a 7.5". Does anybody have any more information about it? Thx Rick
    Stallion #378
    Suzuki Burgman 650
    rick I also have a drip out the pinion seal. But I've just been living with it. Sorry don't know the answer.
    Rick, rare for a rear cover to leak but it can happen. You can use this to make a new gasket for the cover, for the pinion seal i believe a ford Ranger seal will fit. You can match up the numbers from the old seal at a parts house
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Several years ago I made a couple of trips to the factory in Troup, Texas and both times had the full tour of the place. Both times I observed a mechanic shortening rear ends to fit the Stallion. Both times I was told they were Mustang rear ends. After cutting them down to size and reweilding them, they installed 410 gearing. I'm sure your local Ford mechanic could look and tell you what you have. Tomg
    Dec 2013
    Hot Arizona, USA
    Just came back from the shop. They're pretty sure it's the pinion seal. Since I don't have a lift, and I don't feel like laying under it, I'm going to let them do it in a couple of weeks. Rick
    Stallion #378
    Suzuki Burgman 650
    Dec 2013
    Hot Arizona, USA
    Quote Originally Posted by tomg View Post
    Just for info, when a shop had it apart, when I was looking at changing the gearing, whoever put it together didn't have it set up correctly and the gears were rubbing on the housing. Rick
    Stallion #378
    Suzuki Burgman 650
    Dec 2013
    Hot Arizona, USA
    Tom, you are correct. It is an 8.8 Mustang rear end. When the did the seal, they said it was from a 2004 Mustang.
    Stallion #378
    Suzuki Burgman 650
  1. no rear brakes on 2011 Vision Crossbow rear end.
    By Buellee in forum Lehman Trike
    Last Post: 05-22-2019, 10:28 PM
  2. Photos of your rear end —. Not THAT rear end !!!!!!
    By Snickers1948 in forum Harley Tri Glide
    Last Post: 11-04-2017, 02:07 PM
  3. Replies: 20
    Last Post: 03-29-2011, 02:36 PM
  4. Rear end clunk in Valk CSC trike
    By TXTrikeNewbie in forum California Sidecar Trikes
    Owners Forum
    Last Post: 01-01-2011, 06:07 AM
  5. Need a Rear end for custom/production Trike
    By zapmanjay in forum General Discussion
    Last Post: 11-16-2008, 04:04 PM
