Lehman Trike Swingarm Monarch II (reconditioned) ready to use
Status
Not open for further replies.
Lee H. Mann
Gone But Not Forgotten
Apr 9, 2011
4,021
7,367
Martinsburg, WV
LEHMAN TRIKE MONARCH II SWING ARM THAT HAS BEEN COMPLETELY RECONDITIONED.
PROFESSIONALLY REPAIRED BY A CERTIFIED FABRICATING WELDING SHOP TO ORIGINAL FACTORY MEASUREMENTS.
ALL OF THE ORIGINAL FACTORY DEFECTS HAVE BEEN IDENTIFIED AND ADDRESSED SO THAT THIS SWING ARM IS BETTER AND STRONGER THAN IT EVER WAS NEW.
PLACED ON A FACTORY STYLE JIG FOR CONFORMITY.
I BOUGHT THIS SWING ARM FROM AN UN-WRECKED, UNDAMAGED KIT BECAUSE RIDER WANTED INDEPENDENT SUSPENSION.
OVER 11 HOURS WENT INTO THE REPAIR, SO I DOUBT I WILL EVER CONSIDER DOING ANOTHER.
THIS SWING ARM IS READY TO INSTALL AND INCLUDES NEW LB6301 ISO BUSHINGS, SLEEVES AND FRONT DRIVESHAFT BOOT.
SHIPS FREE TO LOWER 48 STATES ONLY.
IF YOU HAVE A CRACKED SWING ARM ON YOUR LEHMAN MONARCH II STRAIGHT AXLE TRIKE CONVERSION WHERE THE KIT WAS MANUFACTURED BETWEEN 2004-2012, THIS IS YOUR QUICK TICKET OUT OF DESPAIR.
IT IS LISTED ON eBAY FOR $1795.00 BUT T/T MEMBERS GET IT FOR $1550.00.
contact me at www.mjtrikes.com
Hi Lee, I just bought a 2004 goldwing trike with a Lehman Monarch 2 conversion. The swing arm isolator bushings are totally deteriorated. Trying to figure out how is the best and easiest way to get in there to replace the bushings. Do I need to take the body off or just the tires or what? plus I need to figure out what parts I need and where to find them.
William sorry to say but Lee passed away last year maybe somebody else will have some information for you about your Lehman conversion..
William. I have a 2005 that had the same thing with the bushings.
It was more then I wanted to tackle so I took mine in. Gene's Gallery in Springfield Mo
He said it was a big job. Tires, Mufflers, Drive shaft, Stabilizer arm. He said the new bushings were a little oversized and had to use a lot of lube and clamps to get them in place.
I have the same issue. Does anyone know where I can get the bushings (LB6301)? In the shop now, but they can't find the bushings.
Status
Highwayman 90
Highwayman 90
