Likes Likes:  17
Thanks Thanks:  12
Results 1 to 12 of 12
Thread: Fuel Gauge on CSC with Auxiliary Fuel Tank
    300+ Posts paid4c4's Avatar
    Mar 2016
    Crestview Hills, KY, USA
    Default Fuel Gauge on CSC with Auxiliary Fuel Tank
    My DCT/CSC trike was built with an auxiliary fuel tank. My question; does the fuel gauge read just the GW fuel tank or total fuel on board?
    Bill
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    It reads the stock GW 6.6 gallon fuel level. The auxiliary tank gravity feeds slowly into the GW tank when the the GW tank drops below a certain level.
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    My CSC/Goldwing fuel gauge measures the original tank level. From my experience what I see is the needle starts to move after the first 30 to 35 miles and goes down rather rapidly until about the 3/4 level. Then is is real slow to get down to 1/2 tank. And slower after that.
    When my warning light comes on I still have over 2 gallons in the tanks. I don't know for sure but I suspect the aux. tanks' top is slightly lower than the OEM tank and the bottom of the aux. tank is relatively even with that of the OEM. Anyway, that's how the fuel gage is reacting..... Jim
    2014 CanAm Spyder RTL SOLD
    Semper Fi
    Mar 2016
    Quote Originally Posted by cScjhb View Post
    My CSC/Goldwing fuel gage measures the original tank level. From my experience what I see is the needle starts to move after the first 30 to 35 miles and goes down rather rapidly until about the 3/4 level. Then is is real slow to get down to 1/2 tank. And slower after that. When my warning light comes on I still have over 2 gallons in the tanks. I don't know for sure but I suspect the aux. tanks' top is slightly lower than the OEM tank and the bottom of the aux. tank is relatively even with that of the OEM. Anyway, that's how the fuel gage is reacting..... Jim
    Jim, thank you for the explanation. I have about 30 miles on a full tank and noticed the gauge starting to move. I'll keep watching it now that I know what to look for.
    Bill
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    This is also what I experience.
    When my low level fuel light appears on the dashboard, I have about 2.5 to 3 gallons left in the tanks if I refill at that time.
    If I assume 10 gallons volume in my main tank and auxiliary tank at my average 34 mpg at sea level, then I have a range of about 340 miles per both tanks. I will watch the fuel trip odometer more closely than the fuel gage, which is reset at the fuel refill. At the 300 mile mark, I know its time to top off and I will not second guess it with a gallon plus in reserve.
    So my recommendation is, calculate and know your average mpg, based on your riding preferences and geographical location, and multiply it by the total of your stock and auxiliary tanks volume to get your total average miles per combined tanks. Then preset one of your trip odometers to track your mileage per each refill.
    You can't go wrong. I mentioned geographical location in the above paragraph because at sea level I average 34 mpg. I will average 37 mpg while in mountainous terrain but will still refill at the 300 mile mark.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    When the low fuel light comes on, set your trip meter to zero and you have 90 miles worth of fuel left. I have not tested it to empty, but Will at CSC told me that this is what the range is, actually he says a bit more than 90 miles, but 90 miles is a safe bet.
    Mar 2016
    Randy, thank you for responding and that makes sense. The fuel gauge reads what is in the OEM fuel tank and when it reaches LOW FUEL you still have the auxiliary tank which is full or close to full to provide another safe 90 miles. I'm down to a half tank on my first fill up and will try out what has been posted. I'll report back.
    Bill
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Bill, My CSC/Goldwing is my first trike but not my first wing. It took me a little bit to become familiar with the difference in how the fuel gage registers. I tracked my mileage and fuel usage in detail for over 4,000 miles. There has been only one time my fuel light came on and then it took only 7.1 gallons to fill. My MPG has been consistently right at 34. I find that my bike will go about 160 miles until the fuel needle is exactly at 1/2. When filling the tank it takes some patience. It can appear full but a real slow drizzle of fuel can add an additional gallon or more. I'll be interested to hear about your experience. Good luck..... Jim
    Semper Fi
    Sponsor
    TrikeTalk Sponsor
    Trikemaker's Avatar
    Aug 2017
    Arrington, VA, USA
    Gentlemen,
    I have attached a quick drawing of how the CSC aux tank works so that you can get a visual reference.
    If you have any other questions let us know.
    Hopefully you can see it.
    Name:  Aux Fuel Tank Schematic (Large).JPG
    Mar 2016
    Todd, thank you for the photo it helped me to understand how the system works. This will enable me to make better use of the auxiliary tank and my fuel system in general. Just one thing, could you please show where the Honda takes fuel out of the tank and sends it to the engine? Curious minds want to know!
    Regards;
    Bill
    Sep 2015
    Oriskany Falls
    Quote Originally Posted by paid4c4 View Post
    Regards;
    Bill
    I'm not Todd ,but i can tell you for sure the fuel is taken from the top of the Honda tank ,the pump is directly under your butt
    Sponsor
    TrikeTalk Sponsor
    Trikemaker's Avatar
    Aug 2017
    Arrington, VA, USA
    Yes nywinger you are correct.
    The Honda fuel pump sits on the bottom of the honda fuel tank and then pumps the fuel out the top through a fitting at the top of the tank. The vent, pump power wires, sender wires, fuel line out, and fuel line in, all go out through various flanges depending on the year of the motorcycle. These can mostly be seen when you remove the seat.
  1. Roadsmith Unveils New Auxiliary Fuel Tank Option for Harley-Davidson Touring
    By Trike Talk News in forum Roadsmith Trikes
    Owners Forum
    Last Post: 12-17-2019, 11:02 AM
  2. Auxiliary fuel tank
    By Maurice in forum Harley Tri Glide
    Last Post: 11-26-2016, 10:48 AM
  3. Trike Auxiliary Fuel Tank
    By tndragonrider in forum Honda Trikes
    Last Post: 02-23-2016, 07:40 PM
  4. Slow filling of Auxiliary Fuel Tank
    By ibsteve in forum Honda Trikes
    Last Post: 03-07-2013, 10:47 AM
