Likes Likes:  3
Results 1 to 7 of 7
Thread: No brake pedal return.
    100+ Posts 1 triker's Avatar
    Dec 2018
    Hempstead,tx,Waller County
    Default No brake pedal return.
    Maybe someone can help me on this, 2013 Stallion, the brake pedal will not come up after pressing it. I've changed master cyl, booster and proportioning valve and still will not come up, I have to pull it by hand.
    # 796
    What happens if you open a caliper bleeder when this happens? Do you get fluid out and does the pedal release?
    Pump the brakes up till you feel them get hard, start the trike up. The pedal should drop off slightly. You have just tested your brake booster, to rule it out. When you changed the booster did you by chance mess with the push rod for the master cylinder? In correct adjustment would change your free travel and could cause the brakes to lock up and the pedal to not return
    250+ Posts
    Dec 2010
    oly,wa
    Good morning
    this problem has happened to me twice. I believe the problem lies in the front calipers
    when you put on the brakes the cups expand to put pressure on the pad and then do not return
    when the pedal is let up. Take caliper off like you would to change pads and then check cup area.
    clean up really good with brake cleaner and brush. you will probably half to rebuild them eventually.
    Dragon
    Good morning
    Dragon
    Cleaning the caliper pistons is ALWAYS a good start before installing new pads
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    From your description it's sounds like the linkage is binding or seized up. See if it moves freely when disconnected.
    Jun 2021
    East Troy
    Default stallion
    Quote Originally Posted by 1 triker View Post
    Do you have a spring about 6" long under the bike pulling the break rod back?
    950+ Posts
    Jun 2013
    DFW, Texas
    Did you get your problem solved?
  1. Spring return on the parking brake is not working.
    By cigarman in forum Harley Freewheeler / Road Glide 3
    Last Post: 07-23-2016, 01:48 PM
  2. Over size brake pedal
    By felixpirozzi in forum Honda Trikes
    Last Post: 12-08-2011, 09:54 AM
  3. Brake Pedal Extension
    By rmrc51 in forum Honda Trikes
    Last Post: 10-11-2010, 12:44 PM
  4. Stallion brake pedal.
    By DEIC in forum Stallion Trikes
    Last Post: 11-13-2009, 07:34 PM
  5. moving a brake pedal plus other
    By acmeactor in forum General Discussion
    Last Post: 11-05-2009, 04:55 PM
