14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  3
Thanks Thanks:  1
Results 1 to 12 of 12
Thread: Newbie with tracking issue
    5+ Posts kimrpaige's Avatar
    May 2021
    S. Daytona, FL
    Default Newbie with tracking issue
    Hello All,
    I just joined this forum, actually stumbled across it by accident. Anyway, I own a beautiful 2013 HD Ultra Limited with a Roadsmith kit. I bought it a little over a year ago with 1250 original miles on it, it is all chromed out with optional chrome front wheels as well as chrome rear wheels, and also running boards. Its painted yellow and black, will post pictures of it on here soon. It has a little over 7,000 miles on it now.
    Now to the issue at hand, It has always pulled a little to the right, Air pressures are set both the same in the rear, new tires all around as the old ones were like new but old. Steering head bearings are fine also. I took it to the trike shop here in Daytona, and the main technician there (Randy) immediately saw that the LH wheel/tire was further forward than the RH one by about 1/2 inch by looking at the relationship between fender and tire.. I left it there for him to adjust or align, he said it can be done pretty easy.
    Just wondering if this is a common problem or just an isolated case of when it was triked out someone goofed. I also had a issue with the front wheel bearings wore out prematurely as the spacer in the front wheel was not the correct size. Not sure where the kit was installed, I am assuming at the local HD shop here in Daytona as it was sold new there. Can someone here tell me what all is involved in getting the back wheels aligned so it will track straight, my left shoulder/arm gets tired after a while, LOL. Thanks in advance, Kim
  2. Roadsmith banner
  3. #2
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    I can't help with your problem but welcome to Trike Talk Kim!
  4. #3
    Welcome To trike Talk .....Kim..........
  5. #4
    1250+ Posts Dave59's Avatar
    Dec 2015
    Mayville Wi USA
    Hey Kim, Welcome to Trike Talk!!
    "No matter what you ride, give respect to get respect"
    2016 Billet Silver/Black Tri Glide
  6. #5
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Sounds like the trees aren't raked. Trikes can have a slight right pull do to road crown. Raked trees will make things much better. I don't think I would align anything to a fender gap.
    Hi Kim, to Trike Talk
    Have a look here to get more info on your Trike Kit
    https://roadsmithtrikes.com/trikes/hdt/
    Sponsor - Roadsmith Trikes
    TrikeTalk Sponsor
    Roadsmith Trikes's Avatar
    Mar 2008
    MN
    Kim - congrats on the "new to you" ride! Looks beautiful. As another member posted, do not have the tires aligned using the body or fender well as a guide. If there isn't any unusual tire wear on any of the three, probably good sign there isn't an alignment issue. Probably more to do with either the trike having stock triple-trees, or if the trees have been replaced, they didn't have enough angle change.
    Trikes having a slight pull to the right is not unheard of. Maybe put a little less air in the left tire, I know some customers try that. The pull should really be no more than the weight of your hand to correct. However, Florida has some very highly crowned roads, particularly near the coast lines. All of these are factors. Give it some time and you will get used to it.
  10. Roadsmith banner
  11. #9
    welcome Kim your situation is normal unless it has a strong pull. My 13 Tri has had it since new and I have 63k on it now. Long ago got used to it.
  12. #10
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Hi Kim, welcome to the forums from the west coast of Florida. I had a '15 Tri that pulled just slightly to the right from the day I bought it, I did get used to it because of the road crowns.
  13. #11
    Quote Originally Posted by Zammy View Post
    My 15 and 17 Freewheelers both drifted right
    The 21 I am probably going to buy drifts slightly right also
  14. #12
    May 2021
    S. Daytona, FL
    I got the trike back yesterday, and it seems better, but still a slight pull to the right which is probably due to road crown. Will have to ride it more to see. I do not know if the triple tree is raked but pretty sure it is as the kit has many options. The mechanic showed me a kit he was installing and the new kits are raked even more than when my kit was installed. I will update once I ride it a bit more. Thanks again, Kim
  1. Boom Audio GPS tracking
    By David792 in forum Harley Tri Glide
    Last Post: 04-13-2021, 08:45 PM
  2. tracking syatem
    By nightstalker in forum Honda Trikes
    Last Post: 04-21-2015, 09:37 PM
  3. Stallion tracking issue
    By larryxcop in forum Stallion Trikes
    Last Post: 07-26-2014, 10:42 AM
  4. Real-time GPS tracking via the web
    By JohnC in forum General Discussion
    Last Post: 09-20-2013, 07:21 PM
