Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  1
Results 1 to 5 of 5
Thread: Exhaust Help!
    100+ Posts
    Sep 2010
    NORTH DAKOTA
    Default Exhaust Help!
    Ok here's my dilemma:
    I have a 2021 Tri-Glide. I was going to install the Street Cannon Mufflers and headers but they are not going to be available anytime soon. I could do without the headers but the mufflers are backordered until God knows when.
    I already have the S/E 447 Torque Cam, the S/E Tuner, and the S/E High Flow A/C that I'd like to install.
    So, what is my slip-on muffler option at this point? I can always change the exhaust system/tuner for something more high-performance at a later date (after the warranty expires).But I desperately need to know what is the BEST Slip-On muffler option for my current set-up that might actually be available.
    Any help would be greatly appreciated!!
    You first need to talk with your dealer to see how this will affect your warranty. H D is getting real tight about this.
    You could make the changes you already have while waiting for new exhaust parts. You would then reconfigure your tuner
    200+ Posts Wmitz's Avatar
    Jun 2018
    Crossville, TN, USA
    Might want to put the brakes on, lol. If you are going to put a performance headpipe without a cat and free flowing mufflers, the SE tuner is out. It doesn’t have enough capabilities for such an open system. Remember it is a epa tuner, that requires a cat. Think things thru a bit more. Check around for performance pipes with cats that will work on a trike. Like Jack mentioned, warranty will come into play with aftermarket parts. Didn’t know HD made a performance headpipe that was certified for a trike.
    400+ Posts
    Jan 2015
    Barrington, NH USA
    Check some of the various Forum classifieds for a used set of the Street Cannons. Maybe even check eBay. I'll bet there are some out there. With a trike a scuff or two will never be seen.
    200+ Posts New Orleans Kevin's Avatar
    May 2021
    Arabi, LA USA
    Default 2021Exhaust
    From what I’ve been told I can change exhaust to any mufflers I want as long as I leave the cat in the head pipe I keep my HD warranty
    All those parts you have should work together but you’ll still need the right mufflers to get the best Horsepower or torque depending on what you’re looking for.
    I’ve found AARON at Moonshine HD has a wealth of knowledge as to what works with what . My 2017 FLHXS screams with the camchest kit/pipe/ breather/dyno tune they recommended( power vision)
    The day after my new warranty is done the serious upgrades will start.
  1. Help, I have gas coming out of exhaust
    By memetriker in forum VW Powered Trikes
    Last Post: 02-02-2016, 09:15 PM
  2. Help help
    By Old Goat in forum Honda Trikes
    Last Post: 07-27-2010, 09:49 PM
  3. Need some help with exhaust
    By johnchaparteguy in forum General Discussion
    Last Post: 03-18-2010, 12:38 PM
  4. Exhaust Help 2005 Sportster with Trike Kit
    By xxzeus34xx in forum Harley Trike Conversions
    Last Post: 03-10-2010, 03:16 PM
