Likes Likes:  2
Thanks Thanks:  3
Results 1 to 8 of 8
Thread: Display is BLACK
    User ID
    32293
    May 2021
    Dalington
    Default Display is BLACK
    Question: I have a 2010 Audio Comfort with only about 8K miles on the clock. 2017 Road Smith Kit. Over the years once in a while my display would just be black, now it is almost every time I start it. I have reset all the plugs on the back of the display. Thoughts? Suggestions???
  2. Roadsmith banner
  3. #2
    75500+ Posts
    User ID
    6298
    Mendham NJ USA
    Steven.......Welcome to Trike-Talk.........I can't help with your problem but I'm sure someone will chime in soon with some help....
  4. #3
    TrikeTalk Moderator
    User ID
    976
    welcome
  5. #4
    1000+ Posts
    cScjhb's Avatar
    User ID
    31029
    May 2020
    Mesa, Arid-Zone-A
    Welcome to TT Steven. It will help if you identify which bike your kit is installed on. Make, model, etc. I'm sure you will find some helpful information here..... Jim
    2008 Honda GL1800/California Sidecar Trike
    Semper Fi
  6. #5
    1000+ Posts
    cScjhb's Avatar
    User ID
    31029
    May 2020
    Mesa, Arid-Zone-A
    OK. I see your profile picture shows you have a Honda GL1800. Do you also have nav. on the bike. If so, the display loops through your navigation electronics housed on the front wall inside your trunk. Take the cover off and you will find a little pin hole in the top of the unit. That is a reset button. You can use a paperclip or something to GENTLY push down and reset your system. Do this with the key on and watch your screen. Don't push too hard. You don't want to break something. You don't need to remove or unplug the nav unit. This is a pretty easy process and only takes a few minutes to do. Good luck..... Jim
    Semper Fi
    User ID
    32293
    May 2021
    Dalington
    Quote Originally Posted by cScjhb View Post
    Jim, I did as you suggested... Sadly no relief.. Still Black. I am afraid the screen may be burn/shorted out. It has done this once in a while even before we triked it. So I am going to pull it off, clean and check all contacts/plugs, and see if that helps.
    Thank you for your suggestion.
    Steve
    1000+ Posts
    cScjhb's Avatar
    User ID
    31029
    May 2020
    Mesa, Arid-Zone-A
    Next, I would call Mark DeSimone At D&D Discount Motorcycles in Tempe, AZ. 480-731-9003. Mark is the technical writer for Wing World magazine. He KNOWS Goldwings and may have some insight for you. Again, good luck and welcome to TT..... Jim
    Semper Fi
    1750+ Posts
    User ID
    23660
    Sep 2016
    Springfield, Mass. USA
    Excellent suggestion here::: I just put his number in my cell phone myself............
  10. Roadsmith banner
  1. air shock pressure display
    By iccco in forum Honda Trikes
    Last Post: 12-09-2015, 03:23 PM
  2. Motor Trike LED Display Fix
    By Gold Rush in forum Honda Trikes
    Last Post: 08-29-2015, 04:26 AM
  3. Flag Display
    By DocGrizzly in forum General Discussion
    Last Post: 08-31-2014, 09:26 PM
  4. Roadsmith Trikes to Host Two Display Locations at Sturgis!
    By Roadsmith Trikes in forum Roadsmith Trikes
    Owners Forum
    Last Post: 07-22-2014, 03:59 PM
  5. Halloween display
    By flyer91 in forum General Discussion
    Last Post: 10-26-2011, 01:17 PM
Bookmarks
