SSpoon4SullyNew Member Introduct...Hello from VA
SSpoon4Jack KlarichNew Member Introduct...Hello from VA
SSpoon4GorillaNew Member Introduct...Hello from VA
SSpoon4SSpoonNew Member Introduct...Hello from VA
Results 1 to 11 of 11
Thread: ABS Light After Trike Conversion
    50+ Posts Bouncer's Avatar
    May 2021
    Milwaukee, Wi, USA
    Default ABS Light After Trike Conversion
    New here so ..... Hello everyone !
    I've got a question I can't find an answer to.
    I installed a Champion Trike kit on my 2011 Harley FLHTC touring bike.
    The bike has ABS brakes. There is no rear wheel sensor option I can find for this trike kit so
    without that, the ABS light blinks continuously while driving.
    I've tried removing the ABS fuse and even un-pugged the ABS unit and the light remains on.
    Did anyone else encounter this problem and remedy it without putting a piece of tape over the light ?
    Jeff just a thought can you tie the two sensor wires together to read just the front sensor?
    May 2021
    Milwaukee, Wi, USA
    I've thought about doing that. I've also thought about splicing into the speedometer sensor. I just don't know that much about these sensors. I believe they work by creating milliamps. I don't know if different sensors create more or less milliamp voltage output and if a milliamp output voltage change would hurt the ABS electronics. Also, the speedometer sensor senses a transmission gear so you get 14 pulses in one revolution verses 1 pulse in 1 revolution of the wheel.
    I have heard the ABS system can be disabled for dyno tuning proposes. If this is true, nobody is willing to tell how it's done and if it stays disabled once you turn the ignition off and back on.
    Jun 2008
    Lovington, NM, U.S.A.
    You may get help from the company service@championtrikesaz.com this company is now in the hands of a new owner. They should have included a 'Reluctor Ring' on one of the rotors to avoid the problem.
    Retired trike builder
    May 2021
    Milwaukee, Wi, USA
    Quote Originally Posted by trike lady View Post
    Thank you !
    I emailed them and will report the answer.
    May 2021
    Milwaukee, Wi, USA
    You may get help from the company <a href="mailto:service@championtrikesaz.com">serv ice@championtrikesaz.com</a> this company is now in the hands of a new owner. They should have included a 'Reluctor Ring' on one of the rotors to avoid the problem.
    &lt;br&gt;<br>
    <br>
    So I contacted Champion Trikes. As of now, they do not have a solution for the ABS equipped motorcycles other then a sticker they will send you to cover the light on the dash ...... LOL <br>
    <br>
    The new owners are working on it and said they would contact me when they resolve the problem.
    May 2021
    Milwaukee, Wi, USA
    Default Update
    50+ Posts Trikeconvert's Avatar
    Oct 2018
    Spring City, TN
    Default I also have the same light on.
    Thanks for reaching out to Champion Trikes of AZ. I had my 2014 FLHTK Limited converted in late 2018 at the Garden Grove, CA factory. Bill Swift nor anyone else ever mentioned there being an issue. Our ABS system is obviously no longer working as designed. I hope Champion Trike of AZ. is looking into this issue. I'm not even sure my Reflex Braking, introduced in 2014 is still operable. I have not been able to find anyone who really knows. I've been told that the ABS pump could possibly fail because of this situation. Hopefully it is operating in a bypass mode, caused by the absence of the rear ABS sensor. I have considered removing the ABS pump if it were to fail.
    Let's keep this post going so as to pass along information to others who have converted ABS equipped bikes.
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    I am curious - if the ABS do not work, why then is there a $300 option for bikes with ABS?
    Look at the options package?
  11. #10
    Jan 2015
    Johnson Creek, WI, USA
    Default Kooltriker
    Go to kooltrikesnorth.com and call Jeff. He has a fix for the ABS bypass.
  12. #11
    Dec 2016
    Wamego, KS, USA
    Default ABS solution
    You can get custom disks cut with your specifications for sensors from a company in China. That's what I'm considering. Here's a link. If you try it, let me know how it works for you. https://www.aliexpress.com/item/2251...a4422e0e3EL2zW
  1. Replies: 5
    Last Post: 05-27-2022, 06:19 PM
  2. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  3. ABS light
    By bike-ezy in forum Honda Trikes
    Last Post: 02-21-2014, 09:48 AM
  4. auxillary brake light.,turn signal running light conversion
    By fogrider in forum Harley Trike Conversions
    Last Post: 08-25-2013, 09:24 AM
  5. Light on after having my 2012 Goldwing triked
    By barnabus in forum Honda Trikes
    Last Post: 05-31-2012, 08:43 PM
