Likes Likes:  1
Thanks Thanks:  1
Results 1 to 3 of 3
Thread: Wilmac VW Master Brake Cylinder
    May 2021
    Wake Forest
    Default Wilmac VW Master Brake Cylinder
    Anybody recognize this and can recommend a rebuild kit or part number? Thanks!Name:  VW Master Cylinder.jpg
    Founder: Roadsmith Trikes
    TrikeTalk Sponsor
    May 2016
    Daytona Beach Fl
    Default MrTrike
    Quote Originally Posted by RMartens View Post
    it is from a 1964-1965 vw bug. has a 17mm bore, very important and not use a newer 19mm bore. i think the last numbers are 023B. call vw shop or napa or go online.
    May 2021
    Wake Forest
    Brake Master Cylinder (17mm Bore), GERMAN, 1965-66 T1, 113-611-023BGR seems to be a match, and now that I know what I'm looking at, I can see the 17 stamped on the bore. Thanks much!
  1. Master cylinder for rear brake
    By jimmib in forum Harley Trike Conversions
    Last Post: 07-15-2020, 12:49 PM
  2. Rear brake master cylinder reservoir idea
    By Dirtydan in forum Victory Trikes
    Last Post: 08-03-2016, 09:40 PM
  3. wilmac master cylinder
    By vicsdc in forum VW Powered Trikes
    Last Post: 09-23-2015, 04:32 PM
  4. 14/15 Trike chrome clutch/brake master cylinder cover kit
    By Big Coup in forum Harley Trike Conversions
    Last Post: 02-19-2015, 09:00 PM
  5. rear brake master cylinder spec needed
    By lardarse in forum Harley Tri Glide
    Last Post: 12-31-2013, 03:18 AM
