Likes Likes:  1
Thanks Thanks:  1
Results 1 to 5 of 5
Thread: 2011 Tri Glide Additional Accessory Plug?
    40+ Posts
    Jun 2021
    Magnolia, DE United States
    Default 2011 Tri Glide Additional Accessory Plug?
    I ordered a set of Love Jug Mighty Mites and they are due in today so naturally I am at work thinking about the install rather than actual work. My bike currently has the accessory plug that resides under the seat in use on my Road Zeppelin seat so I am wondering if there is another plug somewhere else on the bike that I can plug the fans into. I would rather not cut the plug off of the Mighty Mites and wire straight into the battery if I can help it. Also wondering if there is a splitter that can be used for the under seat plug so I can run both off of it. Not optimal but a thought.
    Can anyone help? Keep in mind that I am at work and my HD trike manual is at home, please don't flame me.
    Thanks!
    John
    2011 Tri Glide: Rinehart 4" Slip Ons, HD Road Zeppelin Seat, 1.5" Rear Lift, DK Customs VIED's, DK Customs 1.5" Deluxe Tank Lift and CDW, DK Customs Floorboard Extensions, HD Sirius/xm and CB Modules, Smoked 4" Windscreen, Love Jug Mighty Mites, DK Customs EBS with Black Catch Can
    Touring bikes with an accessory switch on the dash.
    • Remove the seat and find the accessory plug included with your bike. It will be located tucked down a couple of inches at the front of the battery. Remove the rubber plug.
    • Route the Love jugs harness up under the gas tank and secure the harness to existing wires with the included wire ties, or you can use the included self stick attachments, and run the plug to a position under the seat. Make sure the wire harness is not touching the engine or too close to the engine. Also make sure the harness will not be crushed when you re-install the seat.
    • Push the wiring plug from the “Love Jugs” harness into the plug you located from your accessory switch.
      • Turn on the ignition, then your accessory switch to make sure the fans start. Re-install the seat.
    40+ Posts
    Jun 2021
    Jack,
    Thank you but as was posted in my original question, that plug is already in use for my Road Zeppelin seat. I was wondering if there is a second accessory plug elsewhere or if I could use a splitter for both the seat and the jugs for the plug under the seat.
    John
    Quote Originally Posted by cubalz View Post
    Jack,
    John
    I dunno about another plug on your model, If there is a splitter available depending on how big a fuse you have controlling the accessory plug you have hooked up for your seat may be doable
    I do know later models have a plug coming off the ECM you can tap into with a preformed molded plug that is year specific
    40+ Posts
    Jun 2021
    I figured it out. I just bought a 70264-94A Switched Circuit Adapter Harness. That way I can run both the seat and fan off of the same accessory plug. I usually don't mess with the seat since I have it dialed in and the two small fans on the Mighty Mites should not draw much current.
  1. Switched Accessory Plug
    By 52edub in forum Harley Freewheeler / Road Glide 3
    Last Post: 08-10-2019, 12:58 PM
  2. Another question--plug in accessory socket on the left side?
    By cigarman in forum Harley Freewheeler / Road Glide 3
    Last Post: 06-04-2016, 03:08 PM
  3. FLRT accessory plug
    By RedOregon in forum Harley Freewheeler / Road Glide 3
    Last Post: 10-03-2015, 08:42 PM
  4. Electrical accessory plug issue
    By ofscout in forum Harley Tri Glide
    Last Post: 05-28-2015, 11:41 PM
  5. 2012 Tri-Glide accessory plug
    By Miker1358 in forum Accessories
    Last Post: 07-02-2012, 09:29 PM
