Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  4
Thanks Thanks:  1
Results 1 to 7 of 7
Thread: 2014 Triglide electrical problems
    70+ Posts cowboy472's Avatar
    Mar 2019
    Westport Ma.
    Default 2014 Triglide electrical problems
    This all started with heated internal grips shorting. The heater stays on while riding and burned my hands. I replaced the heating element and replaced the jumper wire for the throttle . Now the electrical is going nuts. Cruise control stays on there is no throttle response. None of the accessories work. An the Engine light is on also I don't know where to look any more! Does anyone have any Ideas.
    Tony, check this link to see why your engine light is on
    https://www.fuelmotousa.com/p-29661-...ble-codes.html
    It sounds like you have a short somewhere, a bad battery can cause the lights etc to do strange things. A shorted stator can also cause a problem like this
    Good luck with your problems and keep us informed
    Mar 2019
    Westport Ma.
    Thanks I will look at that. And let you know what i find!
    850+ Posts vwbug72501's Avatar
    Apr 2015
    Batesville, AR. 72501
    Had a similar problem in my younger years when I jury rigged some trailer light wiring in my car. Pulled a boat trailer that had water in the tail lights. Not enough for a dead short but enough for a high current drain short. Condition melted wires inside the harness from the front to the back of the car. Couldn't see the damage from the outside of the harness under the wrap. I'd suggest a close visual inspection of the harness from the battery to the heated grips with a meter and wiring diagram.
    I ended up having to replace the whole harness from the fuse block to the rear of the car due to multiple melt through points. Good Luck.
    Can you easily cut the power to the heated hand grips and clear the codes?
    This would at least tell you for sure what circuit is causing the problem
    You may want to check your fuses also to see if any are blown
    Mar 2019
    Westport Ma.
    Default Found the problems
    First I like to say thanks for all the great help!
    I started checking the heated grips first and found nothing wrong there. But as I was checking the fire by wire there it was.
    The ground wire pin had pulled out of the plug. Making all kinds of problems. It even caused a couple of fuses to pop. After replacing the blown fuses and correcting the ground pin in the plug. Everything has return to normal . Boy did I think I really screwed up!
    200+ Posts
    Nov 2016
    groesbeck texas usa
    I just love happy endings
  1. Mystery Electrical Problems
    By papalarry4 in forum Honda Trikes
    Last Post: 05-01-2019, 04:50 AM
  2. 2013 Stallion electrical problems
    By Rocky330down in forum Stallion Trikes
    Last Post: 02-28-2019, 03:33 PM
  3. 2014 Triglide problems
    By martyjk in forum Harley Tri Glide
    Last Post: 09-21-2017, 08:33 AM
  4. Comparison 2014 Triglide Vs. 2017 Triglide
    By FRR in forum Harley Tri Glide
    Last Post: 10-24-2016, 08:53 AM
  5. Electrical problems - horn, cruise control
    By gctrikeguy in forum Stallion Trikes
    Last Post: 07-23-2011, 07:21 PM
