Likes Likes:  8
Thanks Thanks:  2
Results 1 to 8 of 8
Thread: Parking brake
    Jun 2021
    Landers CA usa
    Default Parking brake
    I just looked at some threads about Hannigan parking brake kits.I have a 99 GL1500 and just put a down payment on a 05 GL1800 with Lehman conversion that I will pick up on july 1st. Both don't have hand brakes.Has anybody here looked into hydraulic inline brake valves( Wilwood makes several different ones)? We used those on our Detomaso Pantera race cars.Installation should be pretty straight forward
    Have a look here
    https://www.bulletbrake.com/
    250+ Posts wehrme's Avatar
    May 2014
    Decatur, IL
    Place a zip tie around the the right side reservoir and snug it semi tight for sizing. Cut off the tie tail.
    When you park, take the tie and slip it across the front brake lever and hand grip.
    Instant parking brake. Slip the tie back on the reservoir when your done... nice holder.
    Cost - $zip
    Brother Mike
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Simplest one I’ve seen at a reasonable price . Thanks Jack for the info
    Jun 2021
    Landers CA usa
    Default bullet brake
    Thanks Jack,that looks pretty good.Picked up the 05 lehman monarchII and surprise,surprise,it has a handbrake.One less thing I have to take care of.Had a nice 500 ml drive home and like it a lot.]Thanks to all that replied
    Jul 2021
    PORT CHARLOTTE, FL. USA
    Default FREE PARKING BRAKE
    Quote Originally Posted by pmenyhart View Post
    Have you tried to simply push the reverse button. That locks drive train on my 1800 Goldwings. Push button running or not - bike will not move. SORRY FURTHER READING OF POSTS CLAIM THIS CAN DAMAGE YOUR CYCLE. SUGGEST THE PARK IN FIRST GEAR & LOCK STEERING METHOD. May want to keep theft insurance paid up.
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    I believe hydraulic brake line valves do not meet any DOT requirements for use as parking brakes. My understanding is parking (emergency) brakes must be mechanically actuated separate from the hydraulic braking system. Having said that, those of us without parking brakes would find hydraulic valve systems very useful. I'm not comfortable depending upon putting the bike in gear in lieu of a parking brake. Don't know if it stresses the transmission or not. But having something like the Bullet Brake in addition to leaving the bike in gear couldn't hurt.....?
    2014 CanAm Spyder RTL SOLD
    Semper Fi
    30+ Posts
    Jan 2012
    Eugene, or
    I have a bullet brake on my motor trike and it works very well. Fairly easy to set, right there when you need it and has never let me down. The only problem I have, and it’s a small problem, is that to set it, it’s a bit of a two handed job. You pull in on the brake handle and then with the other hand, you push in on the small plunger that locks the brake. If the bike is still running, you have to either find neutral and or shut the bike off to free up the clutch hand.
  1. Front brakes as parking brake
    By jjk1646 in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-14-2020, 08:59 PM
  2. Parking brake,required or not???
    By The Wolf in forum General Discussion
    Last Post: 10-22-2018, 03:27 PM
  3. Line Lock or "Reverse" Parking Brake
    By Muleskinner in forum Honda Trikes
    Last Post: 09-20-2010, 12:00 PM
  4. Parking Brake for Hannigan
    By The Wolf in forum Hannigan Trike
    Last Post: 07-10-2009, 05:33 PM
  5. Parking Brake
    By tubaman4 in forum General Discussion
    Last Post: 07-09-2008, 03:35 PM
