Likes Likes:  1
Results 1 to 3 of 3
Thread: 2016 Freewheeler catalytic converter removal.
    20+ Posts
    Aug 2017
    Blythewood, SC, USA
    Default 2016 Freewheeler catalytic converter removal.
    I just got a 2016 Freewheeler and want to remove the catalytic converter. I have a complete exhaust pipe / header pipe off of my 2013 Triglide that I want to use on the Freewheeler. The 2013 unit has been de-catted already. Does anyone out there know if they will interchange? From just looking, so far, they look like they will. Also, I might have to address how the change will affect the performance without adding a fuel pac etc.. BTW, both engines are 103 with the Freewheeler being a "high output", whatever that is.
    Jan 2009
    MA,
    Quote Originally Posted by MGB View Post
    Yea it is the same , bolt on no problem , it should be tuned no matter what , it will run a lot better, cooler maybe better MPG .
    You should add some fuel with a tuner
    The 103s run pretty lean from the factory compared to M8 engines
  1. catalytic converter
    By CORVETTEJOE in forum Harley Tri Glide
    Last Post: 09-04-2019, 08:39 AM
  2. catalytic converter
    Last Post: 09-03-2019, 05:31 PM
  3. Catalytic Converter question
    By Robert53 in forum Harley Tri Glide
    Last Post: 07-16-2019, 01:35 PM
  4. Gonna Gut my catalytic converter
    By J.T.M. in forum Harley Trike Conversions
    Last Post: 04-27-2016, 07:59 AM
  5. Tri Glide Catalytic Converter
    By Mr D in forum Harley Trike Conversions
    Last Post: 11-13-2010, 03:47 PM
