Likes Likes:  3
Thanks Thanks:  1
Results 1 to 7 of 7
Thread: odd sound !
    20+ Posts Mek5o's Avatar
    Apr 2019
    Cheltenham
    Default odd sound !
    I have a 2011 Harley L1200L with a Lehman raider kit, started hearing ODD sound from right side of bike. it seems to come and go! Can make it by swerving bike back and forth, and will make sound when turning right and under load ! I'm thinking left rear wheel bearing ? any thoughts or experience with this happening ?
    Quote Originally Posted by Mek5o View Post
    Wheel bearing would be my guess also........If you ride it for a while with your hand [Caveman style check] feel the right hub..And then feel the left hub and see if its ''much'' hotter..If it is then its a bearing...
    Carefully jack it up, tranny in neutral spin the wheels one at a time. You should hear the noise and feel the roughness in the bad bearing
    Apr 2019
    Cheltenham
    Default bearings
    any idea where to get new bearings ?
    If you can read the number on the bearing, any auto parts store should be able to cross reference it for you. I like Timken bearings
    60+ Posts
    Apr 2017
    Sunbury
    Check end of axle tube where axle shaft exits any grease/oil present indicates bearing failure. Reach up behind tire or look in from back.Its not good once ball bearings start falling out. Had one fail last summer. Parts thru napa no problem. Not a bad job if you have some mechanical skills.
    Apr 2019
    Cheltenham
    Default Thanks
    Just want to thank everyone for their input and suggestions. As it turns out that when I reinstalled the body, I did not get it tightened down and aligned properly and the belt would hit the body at certain points while riding!
  1. Odd Bicycle
    By trike lady in forum General Discussion
    Last Post: 01-28-2019, 07:40 AM
  2. Odd engine maybe clutch behavior
    By JaysGone in forum Honda Trikes
    Last Post: 04-26-2018, 05:08 PM
  3. Seems a little odd.....
    By hbrogan57 in forum Honda Trikes
    Last Post: 01-13-2013, 07:06 AM
  4. Odd Trike-Bajaj Autorickshaw
    By cscsonny in forum General Discussion
    Last Post: 04-08-2012, 04:36 AM
  5. Odd news.....
    By Nana in forum General Discussion
    Last Post: 01-21-2011, 03:28 PM
Tags for this Thread
