Likes Likes:  28
Thanks Thanks:  1
Results 1 to 20 of 29
Thread: How much more comfy would my trike be if i put only 22 lbs in rear tires???
    Sep 2016
    Springfield, Mass. USA
    Default How much more comfy would my trike be if i put only 22 lbs in rear tires???
    I 've been reading much about putting in only 22 lbs in my rear tires, for a smoother ride, instead of the much higher recommended amounts suggested by my trike builder..
    My ride is not as smooth as I had hoped, before triking........
    2010 Honda Goldwing/Roadsmith model
    Won't this lower pressure wear out my rears faster???
    I ride "both" back roads as well as highway riding (70 MPH ish)
    I am not a cowboy with my trike, (I baby it) I ride the speed limit, and enjoy a relaxing ride......... BUT I do many long distance trips.....
    You'll never know till you try it....
    The lower pressure will not wear your tires faster unless you have a severe alignment issue
    These passenger car rated tires are used to supporting alot more weight on a car
    Try the 22psi
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Go for it Ronnie, been running 22 in the rears for over 6 years now.
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    Ronnie, I have been riding the VTX you saw me with for over 6 years with 20# air in the rear and 40 in the front. That recommendation came from experts right here on Trike Talk. You are not carrying the weight of a car with you. My tires wore perfectly. I just replaced them a month before I sold it. Don't remember the date codes. I personally put 25,000 on them. Don't know how old they were. Could have been original tires. It had 58,000 on it when I sold it. I did put a BT45 on the front and ran it backwards. It was still going at 28,000 miles.
    bt
    Sep 2016
    22 LBS in rear will be tried............I'll report back in a few days, after reducing the lbs in rear's
    Thanks all
    Sep 2016
    Thanks all
    Well, since I reduced the tire pressure to #22 lbs all it's done was too rain everyday (or so hot 95*+) that I have not even touched my bike....I'll soon check it out (but it's pouring rain again today)
    Jan 2013
    Sounds like Florida weather.
    Sep 2016
    Quote Originally Posted by cavie View Post
    Butch, when back home (Ma.) give me a call
    Jun 2010
    Indianapolis, In.
    "40 in the front"
    I would lower that to 36 for better ride.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Jan 2013
    "40 in the front"
    Not if your running a rear tire on the front. The majority of the trike crowd from right here on the forum over the last 8 years or so agree with 41 and running it backwards. I wonder what Poppa Zook's take on this is?
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    ​40 or 41 is good.
    Sep 2016
    Well guys,
    I finely had a good chance to ride my newly lowered tire pressure (22lbs) a good long distance.... and I took it on a long ride to the Vermont area (now be advised, too, those that don't know these back roads, in Vermont, I can tell you that some of these roads are so bad that it would "jarrr" your back teeth.....BUT these roads are also long, sweeping, no traffic, wind'ie bike perfect roads...
    I went a total of 189.6 miles Round trip from my home.... Vermont border is 60 miles from my front door......Anyway I LOVE THE TIRE PRESSURE LOWERED DOWN TOO 22LBS., I FOUND THE RIDE SO MUCH SMOOTHER...................SO THANK YOU TOO ALL THAT RECOMMENDED ME TOO LOWER THE REAR AIR PRESSURE...........It's now a pressure to ride my trike again..
    Jun 2010
    Indianapolis, In.
    Don't know who started the 40/41 stuff or why it took hold but, for me I also started with 41 in a reversed BT45 on the front of my Wing trike. Never had such a hard ride, All most like the front forks were solid rods!!!! Lowered pressure to 36. What a difference.
    I encourage you give it a try.
    Patriot Guard
    Was a LEO
    Jan 2013
    Well guys,
    Atta boy Ronnie!!!!
    Sep 2016
    Thank you for the email on lowering the tire pressures...
    Yep I'm totally impressed with the 22lbs now in my rear tires......much smoother, NO MORE like I had before I DEflated them
    200+ Posts New Orleans Kevin's Avatar
    May 2021
    Arabi, LA USA
    Default 22 lbs in the rear, 36 front 2021 Triglide + happy rider
    Once I read this forum I dropped my pressure from 26 to 22 in the rear tires on my 2021 Triglide and it made a world of difference. Then I added the Legends Lift Kit and it rides 100 times better. I'm still thinking shocks because we have terrible roads here, but the lower pressure and lift kit made a world of difference.
    Sep 2016
    I don't understand why you have to REVERSE the rotation, and mount the BT tire backwards...... What's the reason????
  19. #19
    20+ Posts
    Jul 2020
    Maiden, North Carolina, USA
    Good for you to actually give it a try in the real world—way better than talking about it.
    I run 22 rear and 36 front on my RS Wing. Shocks are full soft, larger diameter anti-roll bar comes on as early as possible. EZSteer with firmer front springs up front. Very plush. Very sporty.
  20. #20
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    I had the BT45 on the front of my Gold Wing in forward position. Cold psi was 36. It wore beautifully and never had a problem with grip when riding in the rain.
    It is a popular statement among trikers to run this tire in reverse… I never understood why and didn’t see the logic of doing so.
    Also had Ride-On in the tire..as well as the other 2 tires.
    I don’t know what the reasoning is to run it in reverse position.
  1. Replies: 11
    Last Post: 11-19-2019, 08:40 AM
  2. Making my Harley Comfy
    Last Post: 06-28-2019, 06:58 PM
  3. Lehman Trike Torque Lbs for Wheels
    By Baldy_54 in forum Honda Trikes
    Last Post: 08-26-2012, 09:27 PM
